Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Time Slip Database
Old 05-09-2008, 08:06 PM   #1 (permalink)
Manford's Avatar
Member Number: 54707
Default close to 12's
i have an 05 srt with a needswing downpipe and 23'' slicks,and mm inserts stock everything else
60ft. 1.875
330ft. 5.471
1/8th. 8.459
mph. 81.80
no read out on 1000 ft.
1/4. 13.271
mph. 101.20
guess i should get a wastegate actuator
Slicks, wga, needswings downpipe 13.02@104
Manford is offline   Reply With Quote
Old 05-09-2008, 08:25 PM   #2 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (114)
Not a bad run. The WGA will give you alot more results than the NW DP. Just the WGA will put you in the 12s.
12.0@120 on DRs and 93oct.
addictedtosin is offline   Reply With Quote
Old 05-09-2008, 08:52 PM   #3 (permalink)
CIVICEATER's Avatar
Member Number: 16703
Trader Rating: (10)
Yea you'll probally pick up another 2-3 mph with a wga.
2003 Solar Yellow SRT-4
E1 Turbo
Kinetic WGA
Devils Own W/I with Progressive Controller
MPx 3" Exhaust with Cat
MPx Intercooler
AGP CAI
Stage 3 ECU
Walbro 255lph Fuel Pump
Stage 2 Injectors
Perrin Fuel Rail
AEM Wideband
Aeroforce Scan Guage
Greddy Type RS BOV
Mopar STS
Exhaust Depot Hardpipes
DCR Oil Mod
DCR 5 Layer Headgasket
299hp - 324ft-lbs tq
13.1 - 110mph<----- Traction Ownz Me
CIVICEATER is online now   Reply With Quote
Old 05-09-2008, 08:53 PM   #4 (permalink)
Freaky's Avatar
Member Number: 47525
good job
stage0,cca bfmic, needswings dp no cat, mccord electric opener , agp wga ,dtec fc/bc , front an rear strut bars ,progress front an rear sway bars an springs, tripple pillar pod with auto meter volt an oil pressure guage , turbo xs wideband, turbonetics cold side pipe raptor bov , aem cai,return line ,255 walboro fuel pump, Granatelli wires , 4306 plugs
Freaky is online now   Reply With Quote
Old 05-09-2008, 09:06 PM   #5 (permalink)
Manford's Avatar
racing with slicks is soooo much better than fighting your street tires, went from a 14.07 to a 13.27
Old 05-10-2008, 06:42 PM   #6 (permalink)
bluebeast's Avatar
Member Number: 39695
Trader Rating: (12)
60ft. 1.875
330ft. 5.471
1/8th. 8.459
mph. 81.80
1/4. 13.271
mph. 101.20
Real good time my man! I'd try to get some S2 injectors to go with that WGA. 12s are right around the corner.
ROLL RACING isn't racing. It's just 2 homos speeding next to each other!
11.79 @ 118.53 S3 + bolt-on car
bluebeast is offline   Reply With Quote
Old 05-13-2008, 12:32 AM   #7 (permalink)
lilmike0450's Avatar
Member Number: 56278
I have seen this guy run and he def. had the driver mod going on.
05 White ACR
lilmike0450 is offline   Reply With Quote
Old 05-13-2008, 03:58 PM   #8 (permalink)
Manford's Avatar
i do not consider myself for the driver mod, im 260, but i went on a diet
Old 05-13-2008, 04:05 PM   #9 (permalink)
You can drive the car well...that is what really matters.
Old 05-13-2008, 07:55 PM   #10 (permalink)
Freaky's Avatar
hell yea ... if you pulled a 13.2 on a stock car even with slicks then you got the driver mod .
Old 05-13-2008, 07:58 PM   #11 (permalink)
Thats what I said...we get your clutch fixed and slap some slicks on there and you should be a 12 sec car too.
Old 05-13-2008, 08:24 PM   #12 (permalink)
Manford's Avatar
you could use mine if you want to
Old 05-13-2008, 09:05 PM   #13 (permalink)
Those would work better than the 24.5s
Old 05-19-2008, 12:37 PM   #14 (permalink)
Member Number: 45523
my god 14 flat to a 13.2 with just tires, i know what i am getting
What kinda 60 foots were you pulling with street tires?
Old 05-19-2008, 03:38 PM   #15 (permalink)
Manford's Avatar
my best 60 ft with street tires was a 2.15
Page generated in 0.18606 seconds with 11 queries
