Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Time Slip Database
Old 10-24-2007, 02:57 PM   #1 (permalink)
srT4URBO's Avatar
Member Number: 37484
Trader Rating: (10)
Default 13.2 at 110.96mph
so i went to the track yesterday....ran my car on street tires.....i ran that 13.2 twice and my best trap speed was 111mph....always ran a 2.1 60' on street tires but yesterday i just couldnt hook AT ALL....it was 2.2 all night....but from what i see i should be possibly in the high 12's correct?...i been to the track b4 and i think that was the worst track prep from all the times i was there....
Its modded
srT4URBO is offline   Reply With Quote
Old 10-24-2007, 03:02 PM   #2 (permalink)
ERABBIT23's Avatar
Member Number: 39786
Trader Rating: (45)
on a 1.79 60 foot on slicks powershifting every gear my buddy went 12.38@110 with a couple 12.4 passes. Same trap speeds as u. They will go down a little more if u run slicks maybe to a 106-108 but will still be a mid to high 12's pass on slicks.
http://www.youtube.com/watch?v=IGLseAyeFwY
He also went 12.88@108 on drag radials
493whp/480tq....AGP Powered, Aaron Tuned, Rick Built, Brad Wired!
Check Out ERABBIT23 on Youtube for Videos!
ERABBIT23 is offline   Reply With Quote
Old 10-24-2007, 03:02 PM   #3 (permalink)
fredsrt's Avatar
Member Number: 28151
with that trap you should be well in the mid 12's with slicks on...i ran a 12.901 at 107.29mph w/ a 1.971 60'
NON-TUNED
fredsrt is offline   Reply With Quote
Old 10-24-2007, 03:13 PM   #4 (permalink)
distinctdev's Avatar
Member Number: 22976
Trader Rating: (32)
check out http://www.myslips.com/timeslips.php search for srt-4. and then look through people with the same trap speed as you
should be able to do a nice mid 12 sec pass
Here are a few people with similar traps...
http://www.myslips.com/profile.php?id=120
http://www.myslips.com/profile.php?id=396
http://www.myslips.com/profile.php?id=137
R.I.P. Steven Lorenz 04.04.06
MySlips.com
Bench Racing Stops Here.
distinctdev is offline   Reply With Quote
Old 10-24-2007, 03:25 PM   #5 (permalink)
srT4URBO's Avatar
Trader Rating: (10)
haha nice to hear that.....hmmmmm i was gonna get some drag radials over winter and run my car in spring with possibly only an intake(running on stock airbox) and maybe meth injection?....
Old 10-24-2007, 03:28 PM   #6 (permalink)
srT4URBO's Avatar
Trader Rating: (10)
also if i get DR's what should my tire pressure be and what rpm should i lainch at like 3k?....and would it be necessary to burnout in the waterbox?
Old 10-24-2007, 03:31 PM   #7 (permalink)
Member Number: 41286
Nice runs man.... On street tires too. What r your mods???
BOOST gets you laid.... well most people anyways
NVR KNO is offline   Reply With Quote
Old 10-24-2007, 03:32 PM   #8 (permalink)
ERABBIT23's Avatar
Trader Rating: (45)
drag radials like 12-14 psi of air 3k launch doing a decent burnout till u see smoke!
Old 10-24-2007, 03:35 PM   #9 (permalink)
srT4URBO's Avatar
Trader Rating: (10)
s1, s2 injectors, agp wga(20psi), safcII/wideband(11.6-11.9 AFR), needswings DP/stock cat-back, BFMIC.....and then mopar sts and msd wires...
Old 10-24-2007, 03:37 PM   #10 (permalink)
srT4URBO's Avatar
Trader Rating: (10)
burnout in the waterbox??...isint 12psi kinda low...i would probabably do more like 15psi if i was to guess
Old 10-24-2007, 03:54 PM   #11 (permalink)
I run 12-13 psi cold in my DRs.... With a really good burnout, the pressure will rise to around 15psi. Ive found best results in launching around 3500rpms and then feathering out about 30ft or so then smashing the gas....
Yea a good burnout in the waterbox....
Old 10-24-2007, 03:55 PM   #12 (permalink)
Nice. Best Ive gotten so far is 13.5 on street tires in stock form. I put the AGP WGA on and some DRs and for some reason I cant break a 13.5.... My WGA is killing me though, so Im gonna take it back off and see if just the DRs can get me bottom 13's....
Best MPH is 102 with stree tires though.... It dropped to 100mph with the DRs.
Old 10-24-2007, 03:57 PM   #13 (permalink)
srT4URBO's Avatar
Trader Rating: (10)
sounds good...i'd probabaly try 3-3.5k to see where i like it as well as what my 60' would be
Old 10-24-2007, 03:58 PM   #14 (permalink)
srT4URBO's Avatar
Trader Rating: (10)
anyone else?
Old 10-24-2007, 04:03 PM   #15 (permalink)
srT4URBO's Avatar
Trader Rating: (10)
is this what u would say i should get as for a DR?......http://www.tirerack.com/tires/tires....Force+T%2FA+KD
Page generated in 0.22504 seconds with 11 queries
