Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > TK Motorsports
Old 11-14-2008, 05:04 PM   #16 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
You'll never be able to achieve such a thing. The clearances and tolerances from one bedplate to the next, hell, even from one journal to the next are ALWAYS going to have some small differences. You'd never be able to sell a "one size fits all" strap kit that fits inside the ribs of each journal.
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
Old 11-14-2008, 05:23 PM   #17 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
OK, but still, the kit should come with
3 2 hole pieces
2 4 hole pieces
that would block the BS oil passage, and utilize those holes to strenghen it even more. Also when machine the 2 bigger blocks, you could also drill holes for mounting hardware for a windage tray.
5 blocks + hardware
windage tray + hardware
500$
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 11-14-2008, 06:04 PM   #18 (permalink)
cokey's Avatar
Member Number: 17219
still breaking in the motor.. making me scared to push it up to 600 like i planed lol..
cokey is offline   Reply With Quote
Old 11-14-2008, 06:33 PM   #19 (permalink)
RUSH@TKMotorsports's Avatar
Member Number: 18925
Trader Rating: (156)
I talked to Nick a little while ago and he's gonna chime in on this discussion. Who know, we might all learn something out of this thread We are always looking for a smarter/better/cheaper way to do things.
Co Owner/Operator
Tele: 1-336-510-9329
For ubelievable prices: WWW.TKMOTORSPORT.COM
2005 SRT-4 (603whp at 28 psi/535whp at 22 psi. No spray!!!
2008 Lexus IS350 (stock besides exhaust)
2006 Ram SRT-10 Reg Cab
**RIP Tim Kim**
RUSH@TKMotorsports is offline   Reply With Quote
Old 11-14-2008, 06:35 PM   #20 (permalink)
cokey's Avatar
200? lol.. man i dnt wanna rip apart the motor again for a strap kit.. ugh.. how much if i drive the car there n ya do it
Old 11-14-2008, 06:37 PM   #21 (permalink)
they have to deck the bedplate when it's off the engine.
then you have to bolt it together, bearings and all, the then mic out the holes.
take those measurements, with the ones from the crank journals, then then the difference is your clearence.
Old 11-14-2008, 06:49 PM   #22 (permalink)
Ram48's Avatar
Member Number: 31250
Trader Rating: (30)
Well with your motor and head build, a Steve Lockett built auto trans,
Our removing the factory A/C and installing a manual steering rack. once it is dialed in with the boost at 30 psi. It should do good lol (I Hope)
Ram48 is offline   Reply With Quote
Old 11-14-2008, 10:31 PM   #23 (permalink)
Member Number: 40256
Strap kit
Quote: Originally Posted by DDogsrt461BLK 3.0 View Post
why not just keep it going, and make 2 super long ones and machine it for where the 4 bolts from the Balance shafts go?
My only problem with it,
1 price
2 how is machining the curved I beam of the bedplate, and having all the load ride on 2 less then a 1\4" ribs that the whole main support to ride on?
I personally want to see a key wayed main support ribs, and actually fill the rib, so that the load is completely spread evenly. Even if you don't make them KEYED, and machine the ribs. Why not make 2 bigger ones that have 4 bolts in them, and utilize the balance shaft holes?
I personally found that the bedplate isn't a issue for me. I've cracked cylinders, before anything else in the engine let go.
Hi all. Nick's Dad here. I would like to respond to this post since i am the one who actually machines the bedplate.
1.The strap kit is made from 4140 steel and that is not cheap. PERIOD. We think that will hold up to 800 hp at least.
you will not find a finer piece of work cheaper anywhere.
2&3. Refer back to #1. you really want to spend thousands to key the straps when the castings are all over the place .
This is a good piece that WILL do what it was designed for.
Nick and Rush have done all they can do to bring an affordable product to the market . You can take them at thier word as several guys on here can attest to.
Me? Gimme a small block Chevy motor!
Thanks for giving them your buisness. They will make you a happy customer no matter what it takes.
billmccandless is offline   Reply With Quote
Old 11-14-2008, 10:43 PM   #24 (permalink)
Dad has spoken
Old 11-15-2008, 01:56 PM   #25 (permalink)
cokey's Avatar
na the price is good.. only thing sucks is shipping coast and redoing the machining again.. well ill see how long this block will hold till it goes boom..
Old 11-15-2008, 05:41 PM   #26 (permalink)
Nick@TKmotorsports's Avatar
Member Number: 29616
Our strap kit was installed and tested sucsessfully on SIX different engines before we ever decided to release to the public. This is a quality kit and not just something we slapped together overnight.
RIP Tim
TK Motorsports
Tele: (336) 370-1242
(336) 456-1229
Fax: (336) 841-8402
tkmotorsports1@gmail.com
www.TKmotorsport.com (Under Construction)
98 turbo GSR (R.I.P)
86 Buick GN
98 BMW M3
Nick@TKmotorsports is offline   Reply With Quote
Old 11-15-2008, 09:55 PM   #27 (permalink)
Member Number: 58399
Trader Rating: (36)
nick can you explain to me why you need the oversized bearing? Or in what case you need them, are they thicker or bigger in O.D.
DCR Powered
tcglass1 is offline   Reply With Quote
Old 11-15-2008, 11:53 PM   #28 (permalink)
cokey's Avatar
was that for me? i meant my motor.. if/when i destroy it again i'll get one
Old 11-16-2008, 12:21 AM   #29 (permalink)
Member Number: 41077
currently there are engines making close to 800 WHP without strap kit. The big issue is over 800 whp that the issue comes about.
dsmlights@rage-tek is offline   Reply With Quote
Old 11-16-2008, 12:55 AM   #30 (permalink)
DAN_3KVR4_SRT4's Avatar
Member Number: 28874
Errrr, I wouldnt lol. Everyone to there own, but, I have seen the carnage of when you dont have them and are pushing hard. Shit, thats why we buy insurance right, in case shit.......
DAN_3KVR4_SRT4 is offline   Reply With Quote
Page generated in 0.22031 seconds with 13 queries
