Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Other SRT/PVO Vehicles > Other SRT/PVO Vehicles > Chrysler PT GT/Turbo
Old 05-03-2007, 10:40 AM   #1 (permalink)
Member Number: 45876
Angry Plastic Manifold split at the seams!
My boost leak was the plastic manifold along the left side where the seam gave way. As the leak was spread over a large area you couldn't feel it with your hand, or hear it, but bubble leak tester showed the leaks.
littleblueGT is offline   Reply With Quote
Old 05-05-2007, 07:19 AM   #2 (permalink)
Member Number: 52719
I always suspected this type of thing would happen or had the capability of spliting, cracking rotting from the heat...
S1/AGP WGA/DSMBC/DCR 55TB/DCR OIL MOD/MAXXFAB DP NO CAT/MOPAR DUALS etc...
tremor is offline   Reply With Quote
Old 05-05-2007, 08:30 AM   #3 (permalink)
I used tie wraps around the manifold which helped quite a bit, this should hold it until the new manifold comes next week. Under boost the manifold would flex and separate at the seemd the tie wraps hold the seam together, but there are still leaks. At least it is drivable. I am glad that I have my aluminum manifold as back up. I have a feeling that those people that built their engines, and installed the plastic manifolds are going to have problems, especially when boosting over 20psi. I am tempted to epoxy the seams of the new manifold as a safety measure!
Old 05-07-2007, 07:06 PM   #4 (permalink)
Member Number: 53809
Exactly....
How much boost are you running? How old is the intake manifold?
2004 PT Cruiser GT
5-Speed
PTP SST/Ported EXH Mani, 3" O2, 3" DP, Heart-Throb 2.5", AGP UCP/WGA, MBC, 255 walboro, 55 mm TB, 2005 IN Mani, 2.0 cams, DCR Windage-Crank Scraper/BS Eliminator/Oil Restrictor, AFC, MAP Clamp
Tunning @ 19 psi, waiting on times
PT_GT-Cruiser is offline   Reply With Quote
Old 05-07-2007, 07:49 PM   #5 (permalink)
If you are refering to me.... the most boost I have taken the car to is 19psi at its current setup.
I have been working on a design based off the srt4 intake. Hopefully to gain more volume.
Space is a major problem.
Old 05-07-2007, 07:52 PM   #6 (permalink)
minicuda's Avatar
Member Number: 25331
Trader Rating: (15)
pts have plastic intake manifolds?
minicuda is offline   Reply With Quote
Old 05-07-2007, 08:22 PM   #7 (permalink)
The plastic intake did not come out until 2005. Some early 2005's had the aluminium intake that the 03 and 04 share.
The reasoning behind why alot of folks went to the plastic was.
lighter than the alumi
doesnt act like a big heat sink
smother inside compared to the alumi
plus it has some sort of quirky wedge that the alumi doesnt have that is suppose to help with air flow.
Of course it was cheaper for DCR to manufacture
I have a feeling over time it will start to show its age from the heat that builds up under the hood. My opinion of course.
Old 05-09-2007, 02:30 AM   #8 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
I knew there was a reason I stayed with the aluminum one while everybody else around me went plastic.
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is offline   Reply With Quote
Old 05-09-2007, 09:30 AM   #9 (permalink)
hharper1321's Avatar
Member Number: 2196
one or two failures does not an epidemic make. I've been perfectly happy with my composite manifold, and I was in the first batch to get them....
2004 PT GT -Stage 1 and some bolt ons
1996 Eclipse RS - In the garage and being reborn
hharper1321 is offline   Reply With Quote
Old 05-09-2007, 11:52 AM   #10 (permalink)
Member Number: 32105
if anyone needs a metal pt turbo intake mani let me know i have one off of a 04 with 4 miles on it.
johnny.mac is offline   Reply With Quote
Old 05-09-2007, 11:56 AM   #11 (permalink)
SRT4Quagmire's Avatar
Member Number: 32324
Trader Rating: (108)
I guess you could buy an abs welder and seal it shut?
http://www.justoffbase.co.uk/Tool-Sh...c-Welding-Kits
SRT4Quagmire is offline   Reply With Quote
Old 05-09-2007, 01:59 PM   #12 (permalink)
Member Number: 7260
I would check with Tommy at Haynes to see if he has any kickin around: http://www.haynesspeedshop.com/Store...&cat=39&page=1 if anybody needs one. The plastic intake manafolds are very inexpensive to replace. You can even pick one up at your local DC retailer.
2005 GT Vert, ATX, Stage 1, MaxxFab 3" O2 Housing and DP, Custom Dynomax Ultraflow Exhaust System, Plastic Manafold, AGP WGA, AMX1397TTAB w/Apollo CAI, AGP UCP w/Greddy RS BOV, TurboXS MBC, Mopar BOP, Autometer Boost Guage, MSD Wires, NGK Iridiums gapped at .028, Turbo Timer, Upper and Lower Prothane Motor Mount Inserts, DCR Oil Flow Modifier, BTG Strut Tower Brace, Transman Modified Tranny.
drakos is offline   Reply With Quote
Old 05-09-2007, 08:32 PM   #13 (permalink)
The plastic manifold could have pop revits install around the seams, the epoxy could be used to fill the seam, which would take care of most of the problem. The thing that bothers me is NYLON 6/6 was used to make it, with a maximum operating temperature of 200 deg.F, and is for indoor use! This material may degrade in short order, my manifold was in for 6 months before it went. The last few days here in California we have hit 97 to 100 deg., and in bumper to bumper traffic you know under the hood is over 200 deg. F. Had the manifold been made of true composite the temp and durability would not be a concern.
Old 05-09-2007, 09:57 PM   #14 (permalink)
hmmm I thought it was something like 260c/500f
anyway regardless of the max temp of nylon... it will dignerate over time from long term exposure to heat... (my opinion)
your right we need a better intake... I recycled my alumi intake and had a barbacue....
Old 05-10-2007, 07:13 PM   #15 (permalink)
THier's Avatar
Member Number: 8263
Ok Time to chime in,,, this manifold won awards for its design and construction. If I remember right,, it is not glued or welded,,, basically it was compressed together,, and vibrated,, to generate heat, to fuse it together,,, ok I guess it could be considered welding,, sort of. Mine was the second to go on an 03,, I had the 50trim on when I installed it,, it sees 16psi min,, 26-28 or race gas,, it has outlasted 2 bottom ends,, and two trannys. Could you have gotten a defect,,,, yes,, you are the first I have read of this,,
Good luck with it,
Tom
THier is offline   Reply With Quote
Page generated in 0.18374 seconds with 13 queries
