I am currectly working on taking my '03 Sebring convertible w/ the 2.4 DOHC and turboing it. I have hit a stumbling block along the way which is the ECM. Obiviously a stock ECM isn't going to work w/ a turbo, the SRT-4 one won't work either (no tranny plug) and going w/ a stand alone is big money. Then it dawned on me, the GT Cruiser has the same tranny and a turbo on it factory.
So what I am looking for is the pin out on a GT Crusier ECM to see if it will work or not. I was hoping one of you fine members could hook me up or point me in the right direction. I can't really go any farther w/ this project until I get it figured it out.
2003, 2004 All Chrylser Nationals Sebring Convertible winner
pm me your e-mail adress i have all the pics but don't knwo how to post them
s1, stock turbo, power paq, needswings dp, custom intake, custom cold side pipes, agp wga, ngk plugs, magnacore wires, direct port 100 shot, aem wb a/f of 11.5-11.8, custom intake mani, direct port water injection, 255 pump, second fuel system for nitrous with return line and fpr, 12.3@116 2005 pt cruiser
He's out of town still I believe. I'm waiting for him to compare the pin-outs too, 'cause I'm doing pretty much the same thing, only using slightly different parts. I think he said he's going to get to this when he gets back to his home this weekend.
One of a kind custom turbocharged 2004 Chrysler Sebring LX Sedan
.:CarDomain:.
auto stick i think is a learned thing in the pcm. it is sees the switches it will know it has it. look at the turbo lites you can swao the s1 pcm from a gt into it and vise versa
Yes it's the same transmission. I think brngrhd is right. On the 2nd Gen Stratus/Sebring Sedans (01-06), Autostick was only an option for the cars that came with the 2.7L V6. However, if you swapped out the instrument cluster and the shifter on a 2.4L with one from a 2.7L, you could have autostick on your 2.4L and it works just fine. I haven't done it myself yet, but a lot of people over on 2gss.org have.
Yes, the transmission is the same. The autostick function is in the cluster. Get an autostick cluster, shifter and a small harness and you can turn a non autostick into autostick.
I compared the two pin outs. They are very similar. Enough so that I think it will work. There are 4-5 pins in differant spots, but I believe some wire swapping will take care of that. I just need to do some checking before I go out a get a GT ECM.
My next question is how do I get around the fact that when you order a S1 ECM you need the last 6 of the VIN. Is that tied into somekind of data base that checks if the VIN matches a GT or will any VIN work.
They check the VIN. You can probably set the new VIN to a used PCM if you get the car's PIN and have access to a DRBIII or someone who has a DRBIII.
My local dealer is good to me so access to a DRBIII is not a problem. If I were to get my hands on say a used Stage 1 ECU, what would info would I need to go along with the ECU from the origianal car?
Well the ECU is ending up in a Sebring, not a PT Cruiser... so... yeah... is that going to work?
If you have access to the DRBIII, then yeah, you're 'brings VIN and PIN should be all you need, IF, the PT PCM will accept them. I don't know how much is programmed in as far as looking for check digits to make sure that a PT VIN is being programmed. It may be that only PT VIN's are allowed. I don't know anyone familiar enough with the programming to ask. You could try Stephanie at Flight Systems, just to she if she can give you info. I know she'll tell you they won't do it, but that's different from they CAN'T do it, ya know? Other than that, just give it a try..... Let us know how it goes!
If not, it's EMS time, and that's a chunk o' money!
2004 PT GT -Stage 1 and some bolt ons
1996 Eclipse RS - In the garage and being reborn
