Ok my car seems to be really picky about my boost setting I'm trying to get 14-15 psi out of it but all I can get is about 13 with out it throwing a P2074-(MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION-HIGH FLOW/VACUUM LEAK) and it only throws this when I'm in part throttle, not when I boostin really hard, I'm haveing this problem because my car was running great spiking 16 holding 14-15 but I had a small leak on my BOV plate well I finally fixed it the other day and of course I was boostin like 16-17 cause their was no leak anymore, so of course my ECU didn't like that very much, but ever since then I can't even get it to hold 14 any more without throwing this code. Any ideas on my problem???????
The easiest and best way to get rid of that is S1, hands down. P2074 is an overboost code, which means you're boosting too high for the factory's likings. For now you can turn down the boost if you want, Or you can take the pcm controlled boost out of the loop by capping off the #2 solenoid lines.
O4 PT Cruiser non GT
Stock b****es, come get me
Yea I really want S1 but that probably won't happen till summer, but I was reading something about that earlier do I just cap everything off of just the #2 solenoid and nothing else, do I run the line from the WGA to the turbo cause I've heard of that too before?????
Yeah. If you look at the lines on the #2 solenoid, one goes to the wga, and one goes to the turbo. Unplug those and cap them off at the solenoid...I usually just sick screws in the holes and forget about em. Then run a line from the turbo to the wastegate where you took those 2 lines off of and you're set.
ok cool it seems to be running much better now it spikes like a stock WGA now too, will this hurt my motor cause it doesn't read boost its not going to run realy lean or anything is it????? Thanks for your help so far its been very helpfull.....
yea I would love to but can't right now do to money, but I don't understand why I'm still getting this code i'm only running 13-14 psi not on ecu control anymore and I've had my gauge checked and they said it was right on my car will only do 11 psi stock why is that????
The PCM does know that you are going over that 11 lbs that a stocker runs. Maybe not how much since the PCM does not have a reading, but the PCM has other parameters that allows it to determine what is going on.
i have a stage 0 and i have had no problems. i just got that code but it went away most like do to a one time circumstance. i have a duel stage boost controler slowboys wga. i run 18 psi and i dont spike i goes to 18 and stays at the track i run 20-22 psi and still no codes. just this one time
I hope you have the propper fuel parts necessary as well as a way to clamp your map signal on anything over 18psi, otherwise you're destroying your horsepower that way.
