Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Other SRT/PVO Vehicles > Chrysler PT GT/Turbo
Old 03-27-2008, 11:19 PM   #1 (permalink)
captaincog's Avatar
Member Number: 45112
Post Leaking ATF on 5 speed....
For those that have heard, I took out the 5 speed to the NASA Cali event last weekend and after the second session she was barfing ATF pretty bad. I finally have time tonight to check out the fluid levels. Engine oil was fine and the power steering levels were okay. I do remember seeing ATF pour out the breather of the transmission.
I have yet to check the fluid level of the trans, but assuming that this is not overfilled, then...
Have I burned up a tranny?
Discuss.
1 Loving Wife
2 Great Kids
3 Freakin Awesome PT's
captaincog is offline   Reply With Quote
Old 03-28-2008, 03:17 AM   #2 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
Trader Rating: (18)
So it was ATF and not oil then? Kinda had me worried when you said it was leaking worse right after we installed that oil sending unit. I'm wondering if maybe that's a seal kind of thing, not a toasted trans kind of thing?
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is offline   Reply With Quote
Old 03-28-2008, 02:10 PM   #3 (permalink)
captaincog's Avatar
Question
Yeah, it was knida hard to tell at first. Thankfullywe had cleaned up the bottom quite a bit and you could clearly see the red color of the ATF all over the lower charge pipe.
When I opened the hood I saw ATF running out of the breather, so that is what really has me concerned. Usually one of two things has happened:
1. Overfill-possible, but I am not sure.
2. Burnt bearing that is severly overheating the ATF and boiling it out. I am really thinking it could be this if #1 doesn't pan out.
3. Bonus-bad check-valve/breather? Dunno.....
Discuss.
Old 03-28-2008, 02:23 PM   #4 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (15)
there's is no breather on the tranny, only a full rubber plug on the driverside of the tranny. If that's gone and it's puking out from there, you need a fresh fluid change, new rubber plug for the hole, and a bottle of friction modifier, should be good to go after that.
I got's a fuel cell......................what you got?
Don't call it a comeback..........Thug Life
DDogsrt461BLK 3.0 is online now   Reply With Quote
Old 03-28-2008, 10:51 PM   #5 (permalink)
captaincog's Avatar
I looked again at their is a breather listed on the parts chart under the diagram #7. This is a PT with the Getrag 288 tranny, so maybe you are thinking of the SRT4 tranny?
Here is the link to the PTCrew site with the pictures:
PTCrew.com - Learn it or Burn it.
Old 04-05-2008, 09:46 PM   #6 (permalink)
captaincog's Avatar
Took it to the dealer, they looked for 2 days and could not find the leak. Dye is in the oil now, so drive her till she leaks and take her back in....
Page generated in 0.22620 seconds with 11 queries
