Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Other SRT/PVO Vehicles > Chrysler PT GT/Turbo
Old 01-10-2007, 10:06 PM   #1 (permalink)
justsaynoman's Avatar
Member Number: 3872
Default Interesting problem
Well, bad luck has struck again, completely stock PT GT. making some hard laboring sounds and has sketchy boost, sounds like a whine from the turbo, anyone have any ideas? dealership wont check the turbo, i pulled the airbox inlet and there's no shaft play.
justsaynoman is offline   Reply With Quote
Old 01-14-2007, 10:51 AM   #2 (permalink)
Member Number: 35230
More info.......
Is it making sounds under power? Idle? CEL? Mods? Laboring sound??
Sounds like a boost leak.... Do a test or at least check all the hose clamps / vac lines
Edit: I can't spell
MarksPTgt is offline   Reply With Quote
Old 01-16-2007, 05:27 AM   #3 (permalink)
Member Number: 3872
when it's cold it will have horrible boost, sounds almost like there's something wrong with the turbo when it's given some gas, spool is slow but then it comes on, i think it might be the factory BOV bladder sticking because it's cold, we'll see if it still does it once it's back from the dealership. turbo just seems uber laggy when it's cold, making hard laboring sounds before the boost even starts to build up and takes awhile.
Old 01-16-2007, 12:01 PM   #4 (permalink)
Member Number: 32105
does it only do it when its cold? when it warms up does it go away? my srt swapped 99 neon does this and once it warms up it goes away so i dont ytry to boost when its cold.
johnny.mac is offline   Reply With Quote
Old 01-16-2007, 06:13 PM   #5 (permalink)
Member Number: 3872
yea, we've got some -10 degree days lately and it's been only doing it when it's cold.
Old 01-21-2007, 03:42 PM   #6 (permalink)
srt_jesse's Avatar
Member Number: 45408
Default pt gt prob
check the vacum line behind the turbo i have a friend who put a s2 turbo on his car and the vac line behind the turbo had a really bad leak and it sounded like tires pealling really bad schreeching sound he zip tied it and the problem stoped but it could be any leak not just that one hope this helps
srt_jesse is offline   Reply With Quote
Old 01-21-2007, 04:12 PM   #7 (permalink)
Member Number: 3872
it's kind of like tires on an 4x4 humming down the road when it's cold. it's hard to explain and i cant catch it on video. i've tried tracing all the vacuum lines thinking it might be the little green line off the brake booster that pops off most of the time on the srt-4. pretty much have ran out of ideas from the comon vacuum line problems i had with that car before zippin' all of them.
Page generated in 0.24488 seconds with 11 queries
