Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Other SRT/PVO Vehicles > Other SRT/PVO Vehicles > Chrysler PT GT/Turbo
Old 11-07-2007, 07:25 AM   #1 (permalink)
Member Number: 58514
Default instilation
i was just wondering if anyone knew if you have to take off the intake manifold to change out plugs. im going to be changing them in a few days and it looks like i could but i havent tried yet.
zz beaker zz is offline   Reply With Quote
Old 11-07-2007, 11:41 AM   #2 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
It's possible to do it without pulling the intake manifold off. Just make sure you have a couple long extensions and it'll work out just fine
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is offline   Reply With Quote
Old 11-07-2007, 10:23 PM   #3 (permalink)
alright thanx. i just got my msd super condutors and my ngk iridiums and am really excited to put them in. just hard to find time when i work 30 hours a week and go to school full time. i thought i could get em out with out taking off the mani but just thought i would check before i messed around with em.
Old 11-08-2007, 01:23 AM   #4 (permalink)
gt crew's Avatar
Member Number: 55926
Make sure you have a swivel spark plug socket too, it helps getting around those poorly located manifold fins over the #2 and #3 plugs.
gt crew is offline   Reply With Quote
Old 11-08-2007, 01:41 AM   #5 (permalink)
It does help but it's not completely necessary if you don't have one. It's barely pushing it but like I said I can get it done with about 16" of extensions, you can get the socket on there well enough to break em loose and torque em down.
Old 11-08-2007, 02:17 PM   #6 (permalink)
thanx. i put them all in and it runs fine. yea i had to use a lot of extenstions. i do have a question though. on the #3 plug there was a yellow ish liquid on it.... dont know what it was but it did not smell like gas. it didnt really have a smell to it. that was the only one that was wet and all the others were bone dry. any ideas of what it could be? i would greatly appreciate any info on what it could be or if it has happened to anyone else. i am going to check it in about a week to see if its still there. i am not sure if that is the first time plugs and wires have been changed but it had about 42k on it when i bought it.
Old 11-08-2007, 06:12 PM   #7 (permalink)
KBzPTGT's Avatar
Member Number: 112
Trader Rating: (10)
What kind of plugs did you take out? If they were Champions, they may have been the originals. BUT...if they came out EZ they probably were NOT originals. The factory torques the SOB really tight so the first set out is a bitch As far as the yellowish liquid, I think my first set of plugs had that on them also. It never came back after I changed them out.
KBzPTGT is offline   Reply With Quote
Old 11-08-2007, 07:25 PM   #8 (permalink)
Turbodude06's Avatar
Member Number: 56659
Which intake manifold do u have cause I have an 06 with the plastic one and I don't think I can get to any of them but one without taking the manifold off but I may be wrong haven't had to yet...
MODS:
(05 Stage 2/ Ported stocker/ 3" side exit/ 3'' catless DP/ Big Intercooler/ Tuned DSP/ AEM Wideband/ Walbro 255/ Fuel Return line/ K&N Intake/ Kinetic WGA/ & a Trunk Monkey )
Turbodude06 is offline   Reply With Quote
Old 11-08-2007, 07:40 PM   #9 (permalink)
I think it's actually easier with the plastic manifold because you can take that cover off the mani to reveal an exoskeleton lookin thing that's about the same size is the aluminum one
Old 11-08-2007, 10:54 PM   #10 (permalink)
thanx for the info! that puts my mind to rest. yea they were champion plugs. i was all worried about my engine maybe leaking oil in the piston.
Old 11-08-2007, 11:07 PM   #11 (permalink)
Just run your car for like a thousand miles or so then pull the plugs out and check em out see if you're still getting that yellow stuff and you can go from there.
Old 11-11-2007, 07:16 PM   #12 (permalink)
captaincog's Avatar
Member Number: 45112
Sounds like either some oil residue from the valve cover seal or blowby throught the plug seal from the boost pressure. run it and check it later.
1 Loving Wife
2 Great Kids
3 Freakin Awesome PT's
captaincog is offline   Reply With Quote
Page generated in 0.17622 seconds with 13 queries
