Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Other SRT/PVO Vehicles > Chrysler PT GT/Turbo
Old 09-11-2007, 11:33 PM   #1 (permalink)
Member Number: 43487
Default how to run vac lines
looking for some info on how to run vac lines on a pt cruiser with a stage 2 wastegate. he doesn't have a boost gauge so its hard to say whats going on in there. i sold him the wastegate, he put it on and is having problems, says it boosts then drops it all. before i go down to help him what should i be looing for?
he only has some exhaust work done and he runs a 50 shot of nitrous.
and he's auto
any help would be great
thanks Steve
jr_srt-4 is offline   Reply With Quote
Old 09-12-2007, 10:01 AM   #2 (permalink)
Dream4's Avatar
Member Number: 35728
and he's auto
thanks Steve
The Stage 2 WGA should be hooked up just as the stock one was, (unless he is running a MBC of course), so that the PCM will control PTB, where the SRT4 is usually adjusted to 4mm of preload, the PT should only be approx 2mm, as long as the mounting bracket has not been "adjusted" (bent), but, there is not much you can do without a boost gauge to see what is happening, it sounds as though there is so much boost that the wastgate flapper is blowing open and dumping all the boost pressure.
but again you cant tel with out a boost gauge, also he shoul have a AFR guage to make sure it is not going lean at the higher boost levels.
05'GT Dream Cruiser Series 4, No.1109
My Mods
Our PTs
PT Trailer Project
Dream4 is offline   Reply With Quote
Old 10-06-2007, 03:33 PM   #3 (permalink)
Ghowie's Avatar
Member Number: 33090
Trader Rating: (55)
so he's running spray and a s2 wg with no boost gauge? Sorry man but that should have been the first mod is a boost gauge, not having one is just asking for trouble
Originally Posted by dansrt4
For a shop thats so behind maybe you should catch up on orders before you catch up to me.
Ghowie is offline   Reply With Quote
Old 10-07-2007, 02:02 AM   #4 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
Trader Rating: (21)
/\/\/\ And with spray the second mod should have been a wideband...you can run pretty darn lean in a hurry if you don't know what's goin on under the hood
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is offline   Reply With Quote
Old 10-07-2007, 08:47 PM   #5 (permalink)
hey, i told him not to be using the nitrous, but hey what can you do.
Steve
stage 2, agp wastegate, turbosmart boost controller, borla exaust, cai, centre force dual friction clutch, performance autowerks stage 2 tranny, evilcreations bfmic, solid motor and tranny mounts, energy control arm bushings,
Page generated in 0.13282 seconds with 11 queries
