Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Other SRT/PVO Vehicles > Other SRT/PVO Vehicles > Chrysler PT GT/Turbo
Old 07-10-2007, 02:54 PM   #1 (permalink)
Member Number: 52719
Default Hauling ASS in Grocery Getter's!!!!
Here is what a few are doing. It is growing, not as fast as the 13 sec club but, steadly growing.
Pretty damn good for a rounded off brick, retro, grocery getter, old folk, picnic table car.
Driver>>>>>>>CAR>>>Turbo>>>>>60>>>>>>>1/8>>>>>>>>>>1/4
total sleeper>>PTGT...Big Turbo....1.849....7.790@97.11...11.962@121.13
turbotaguy PTGT...Big Turbo....1.868....7.792@93.03....12.0394@116.22
brngrhd PTGT....Stock/N2O...1.94.....8.073@93.54....12.360@115.67
THier PTGT...Big Turbo......1.966....8.157@87.07....12.684@108.42
ksquared11 PTGT...Big Turbo....2.112....8.496@86.32...12.867@112.11
hyracer PTGT.....Big Turbo...2.144....8.544@88.17...12.914@112.03
S1/AGP WGA/DSMBC/DCR 55TB/DCR OIL MOD/MAXXFAB DP NO CAT/MOPAR DUALS etc...
tremor is offline   Reply With Quote
Old 07-10-2007, 02:58 PM   #2 (permalink)
srt4_texas
Member Number:
Posts: n/a
It's what I plan on getting done on my wife's...just bought it
Doc
Old 07-10-2007, 02:58 PM   #3 (permalink)
KBzPTGT's Avatar
Member Number: 112
Trader Rating: (10)
Good job guys!
KBzPTGT is offline   Reply With Quote
Old 07-10-2007, 03:03 PM   #4 (permalink)
srt4_texas
Member Number:
Posts: n/a
Quote: Originally Posted by KBzPTGT
Good job guys!
What have you done?
From what I could gather...I should do this first:
-stage 1
-wga
-exhaust
Someone on pt crew said not to do wga on an auto for daily driving, but I wanted to see...I know it helped my skittle
Doc
Old 07-10-2007, 07:25 PM   #5 (permalink)
A good start would be, IMO
Stage 1
Good plugs ( I like my ngk's)
Wires of course
Exhuast (3 DP with or without CAT/ 2.5/ 3 inch exhuast)
A better CAI
Some sort of BC (should be able to hit at least 16 psi on stock wga)
DCX Oil Mod
TB
Later
better WGA
Fuel mangagement
Injectors
TRANSMISSION!!!!!!!!!!!!!!!!!!
SRT4 S3 turbofold, 50 trim etc....
As you well know it never ends
Old 07-10-2007, 08:26 PM   #6 (permalink)
Member Number: 55003
mine has ran a 15.20 at 91.25 in ohio at kil kare
ptgt03srt is offline   Reply With Quote
Old 07-10-2007, 08:48 PM   #7 (permalink)
Member Number: 17068
You've a wee bit o' work to do there lad.
Then again, so do most of us!!!
'04 PT Cruiser
Graphite Metallic
Stage 1
VAK
Magnecor
Denso Iridium
14.48 @ 94.25mph
Mike-in-Orange is offline   Reply With Quote
Old 07-10-2007, 09:02 PM   #8 (permalink)
13secPTCruiser's Avatar
Member Number: 30848
13secptcruiser... PTGT...stock Turbo....1.932....8.534@81.79...13.317@103.02
13secPTCruiser is offline   Reply With Quote
Old 07-10-2007, 09:28 PM   #9 (permalink)
PTGT... Auto.... Stock Turbo...2.07... 8.891@77.98...13.913@98.47
owned by KMG
Old 07-10-2007, 11:49 PM   #10 (permalink)
KBzPTGT's Avatar
Member Number: 112
Trader Rating: (10)
MIO, straighten yo stuff up.
You're way out in right field
Old 07-10-2007, 11:56 PM   #11 (permalink)
srt4_texas
Member Number:
Posts: n/a
So can some of y'all estimate:
stage 1
plugs
wga
exhaust
It has an auto...can you guess at all a 1/4 mile time? Just getting an idea here...
Doc
Old 07-11-2007, 12:13 AM   #12 (permalink)
Member Number: 49623
stage 1
plugs
wga
exhaust
Doc
It should take you into the mid high 14's(depending on where you run). Stock is solid mid 15's. But you need to be careful with the wga, the AGP and & auto tranny do not like each other and PTB can be a bitch to live with some use the S2 wga from the SRT4.. You understand why. AJ is building an awsome 41TE so when not IF you blow up the auto you can call him and get it bullet proof.
Check out ptcrew and meet most of the other crewbies..
and add a set of metal intake pipes TTAB & UCP.. They do help the turbo spool up a lot..
That Green PT GT you can't pull away from.
Bosch is offline   Reply With Quote
Old 07-11-2007, 08:41 AM   #13 (permalink)
does anyone here actually use the auto stick feature when they run?if so what rpm do you shift at with it?
Old 07-11-2007, 08:58 AM   #14 (permalink)
1badsrt-4's Avatar
Member Number: 21276
Trader Rating: (53)
Wow nice work guys you have them things moving
11.34 @ 128.33 mph. Stock motor, head, cams and ecu
1badsrt-4 is offline   Reply With Quote
Old 07-11-2007, 09:40 AM   #15 (permalink)
KBzPTGT's Avatar
Member Number: 112
Trader Rating: (10)
with the OEM transmission, some let the car shift its self in 'D'. It shifts a little earlier around 55-56k rpm.
If you leave it in a/s mode and DO NOT MANUALLY shift it, it will shift at redline (6250rpm?) in each gear.<~~ it's a safety feature to not blow it up
As far as shifting it manually in a/s mode while racing, the shifts are SO SLOW, it's pointless.
AA Motorsports upgraded tranny changes all that
Check out www.PTCrew.com for more info
all above info is hearsay
Page generated in 0.19970 seconds with 13 queries
