#1 (permalink) |
![]() Join Date: Aug 2005
Member Number: 33061
1st question I have is how much boost does a stock 03 PT GT run?
How much boost is safe to run on the stock turbo/ wga? Where do you hook a boost gauge to in a PT GT? My buddy bought one the other day, and wants to hook up a boost gauge, and up the boost a little, and I didn't know if the turbo and the wga was the same, as in the spring and diaphram in the wga as the srt-4's. I also need to know where to take the boost gauge line. It will be a mechanical gauge. Nothin fancy for him, he's married with a 1 year old kid, and the wife isn't into loud, and fast cars to take the kid in. Thanks for all the help.
| Sponsored Links | |
Advertisement |
#2 (permalink) |
SRT of the Month ![]() Join Date: Mar 2006
Member Number: 39786
I could be a good friend and give him my stock WGA from my car to help out because I am kind of guessing they might be a little bit different! I dont know the answer either so when we find out I can probably dig it out of the garage! Or he can get Jay a TCC Customs to hook up his special direct port 800 shot and he can run 7's!
ERABBIT23 "Making Signatures for People Since 2006"
World's Fastest 5 Speed SRT-4 9.87@149 Forum Sponsors: Realtune, AGP Turbo, Rage Tek, and DCR http://www.youtube.com/user/ERABBIT23 ![]() |
#3 (permalink) |
![]() Join Date: Jul 2003
Member Number: 2196
Stock S0 boost is 10-12lbs, depending... How much boost is safe to run on the stock turbo/ wga? As much as a stock SRT. They have the same turbo assembly Where do you hook a boost gauge to in a PT GT? If he has the plastic manifold, there is a boss on the rear he can tap and hook into. If the aluminum manifold, you can tee into the brake booster, or the line on top of the TB... My buddy bought one the other day, and wants to hook up a boost gauge, and up the boost a little, and I didn't know if the turbo and the wga was the same, as in the spring and diaphram in the wga as the srt-4's. I also need to know where to take the boost gauge line. It will be a mechanical gauge. Nothin fancy for him, he's married with a 1 year old kid, and the wife isn't into loud, and fast cars to take the kid in. Thanks for all the help. No problem. Get him a mapclamp, Stage 1 and a S2 WGA, up the boost a bit, and tell him to save for a powerdemon tranny, if it's an auto. If it's a Getrag, tell him to save for a clutch....lol. Either way, any little ricers he comes across will end up VERY surprised!
2004 PT GT -Stage 1 and some bolt on's... Ok, a lot of bolt ons
#4 (permalink) |
hharper1321, Thanks a lot! Now we can start doing some cheap and easy mods to a PT GT! It'll be the only modded one around this area. Most of the people around here that have them are older and not into racing. First time for everything
#6 (permalink) |
Member Number: 2196
So being the same turbo assembly do they start to pull timing at the same boost?
Can we spike like 17-18 on the stock injectors? What size injectors are they? The 03's have smaller injectors than the 04 and up. 04 and up have S1 injectors already installed. Best thing he could do is to install S1. Everything for the PT flows from there. He can then easily up the boost to 17-18 lbs. Hell just do S1 and anS2 WGA and you could spike 18 hold 15 to redline....
#7 (permalink) |
![]() Join Date: Jan 2005
Member Number: 23071
harry is spot on. the pt is the same car as the srt for the most part.
s1, stock turbo, power paq, needswings dp, custom intake, custom cold side pipes, agp wga, ngk plugs, magnacore wires, direct port 100 shot, aem wb a/f of 11.5-11.8, custom intake mani, direct port water injection, 255 pump, second fuel system for nitrous with return line and fpr, 12.3@116 2005 pt cruiser
#9 (permalink) |
Member Number: 2196
Quote: Originally Posted by Wind
How much boost can ya go on the stock PCU?
Unfortunately not much more than stock. The S0 PCM throws all kinds of codes when you play with the boost. Get S1, it's the foundation to build off of, and eliminates all those annoying codes.... ![]() edit: and I realize that you are still waiting on S1, it will come grasshopper, patience.....
#10 (permalink) |
I can't believe taht this thread has never been started before. I can tell him to look for a S1 pcm and we will go from there. What kind of cels come on by upping the boost on S0?
#11 (permalink) |
![]() Join Date: Jan 2004
Member Number: 7260
I have my boost guage mounted on my A-pillar. Looks much better than on the steering column IMO.
![]() 2005 GT Vert, ATX, Stage 1, MaxxFab 3" O2 Housing and DP, Custom Dynomax Ultraflow Exhaust System, Plastic Manafold, AGP WGA, AMX1397TTAB w/Apollo CAI, AGP UCP w/Greddy RS BOV, TurboXS MBC, Mopar BOP, Autometer Boost Guage, MSD Wires, NGK Iridiums gapped at .028, Turbo Timer, Upper and Lower Prothane Motor Mount Inserts, DCR Oil Flow Modifier, BTG Strut Tower Brace, Transman Modified Tranny. |
#12 (permalink) |
![]() Join Date: Apr 2004
Member Number: 10310
Well I am looking at modding my 03. I have a S1 installed already and I have a S2 WGA at home that was going to go on my neon (long story) but now it's just sitting lonley. I can just throw it on and go? What benefits will I get from using the S2 WGA over the stock?
#13 (permalink) |
Member Number: 2196
Throw it on and drive it light for a couple days until the PCm learns it there. Then you should be golden.
#15 (permalink) |
Member Number: 7260
You can do things to minimize PTB like a bigger turbo or external BOV, but it will always be there. You have to "preload" your wga to run and hold at 13-14 psi to redline without the aid of a mbc. Once you achieve that, then fine tune with a mbc. A dual stage boost controller is the best. Run 11-12 psi on 1st gear and 14-15psi for the higher gears. This will minimize ptb and wheel hop. Keep in mind the fluttering sound is amplified with a CAI. You will basically need to re-learn how to drive your car. I always ease off the throttle when approaching 15 psi on medium acceleration. PTB will occur between 15-20psi. If you are getting spikes up to 20 psi, ease off the mbc or tune down the wga. Too much ptb is really bad for our cars. Good luck.
| Thread Tools | |
| Display Modes | |
