Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > Aeroforce Technology
Old 07-21-2008, 07:50 PM   #1 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (17)
Default water injection
i just sent cash for a gauge from you, and i was wondering is there a setting i can use to monitor my water injection?
WTT S2 INJ, FOR DROP IN 650'S
Car Domain
Old 07-22-2008, 01:41 PM   #2 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (31)
Your IAT (intake air temp) should start going lower when the WI is turned on, especially if you have some alcohol in the mix. Since the WI is not a stock system on the SRT4, there is nothing in the PCM that would monitor whether the system is on or off. Maybe someone else who uses a system like this has another suggestion.
Todd
12.80 @ 115
Aeroforce Technology Inc.
forcefedjunkie is online now   Reply With Quote
Old 07-22-2008, 03:24 PM   #3 (permalink)
aww sheet's Avatar
Trader Rating: (17)
i though you'd say that. i unfortunately installed my nozzle after the sensor
Old 07-22-2008, 03:25 PM   #4 (permalink)
Discussion/Performance Mod
NoisufnoC's Avatar
Member Number: 136
only thing i can think of is if you got a water pressure gauge that had a 5v output on it.
omgz!! i haz mods!!
Old 07-22-2008, 03:29 PM   #5 (permalink)
Pit Viper's Avatar
Member Number: 339
Trader Rating: (66)
The problem is that you can have issues with your system and still show pressure on the gauge, such as clogged nozzles.
I'm a huge fan of my Aquamist DDS3 gauge. It monitors flow, is adjustable, with both over- and under-flow safety settings, as well as other safety measures and the ability to trigger other devices based on whether or not your water injection is flowing.
Old 07-22-2008, 03:30 PM   #6 (permalink)
NoisufnoC's Avatar
Member Number: 136
can't you buy a "device" that detects whether water is flowing or not?
Old 07-22-2008, 03:37 PM   #7 (permalink)
Pit Viper's Avatar
Member Number: 339
Trader Rating: (66)
Possibly, but I'm not sure where.
Old 07-30-2008, 10:13 PM   #8 (permalink)
Member Number: 5042
Trader Rating: (31)
When I worked in the Aerospace industry we used flow meters all the time, problem is the expense. These are not simple devices either, and would be difficult to implement in a car. It's been a while since I checked into these, maybe something simpler/cheaper is out there now.
Todd
Old 08-09-2008, 08:53 PM   #9 (permalink)
catlin987987's Avatar
Member Number: 55516
just install one of these
I use them all the time
catlin987987 is offline   Reply With Quote
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.18038 seconds with 13 queries
