Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Aeroforce Technology
Old 04-19-2008, 10:48 PM   #1 (permalink)
Member Number: 21041
Default using scangage in other vehicles
is it possible to use the scangage in any other obdII vehicles? functionssuch as map pressure and such most likely won't work but will others like timing, knock, code reading/clearing etc work? can you damage the gauge or the vehicle pcm by trying to use it in another vehicle? i know scangage (not areoforce) is interchangeable between almost all obdII vehicles, plug and play.
05 black srt-4
95 purply neon
87 rusty 200sx
sschung is offline   Reply With Quote
Old 04-23-2008, 09:45 PM   #2 (permalink)
catlin987987's Avatar
Member Number: 55516
I would think that you can use it for 04-08 dodges
catlin987987 is offline   Reply With Quote
Old 04-25-2008, 06:06 PM   #3 (permalink)
i don't think it would hurt anything to try but i'd like to be sure before i blow my gage or ecu. so anyone else have any input? anyone else tried this?? is aeroforce still on this section? hello?
Old 05-02-2008, 08:28 AM   #4 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (31)
The gauge will work on many 2002-2005 Chryslers, although it has many specific parameters for just the SRT4 and PT Cruiser. Our latest version, released last week, allows you to select a platform in the setup menu first. This then takes you to a list of parameters that are more suitable for your specific vehicle (Ram, Dakota, Stratus, etc). There is nothing new for the SRT4 in the new code. This is still a Chrysler specific gauge.
The reason that the ScanGauge will work on any vehicle is that it is a generic scan tool using generic code. The benefit is that you can use it on many different vehicles, the downside is that in only displays a small number of parameters, has limited features, and updates very slowly.
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 05-05-2008, 04:39 PM   #5 (permalink)
thanks for the info todd. is there any danger to the gauge or ecu if i try it in other vehicles other than chryslers?
Old 05-07-2008, 08:16 PM   #6 (permalink)
Member Number: 5042
Trader Rating: (31)
If you use it on some CAN vehicles it may disable the bus until the vehicle is restarted. I don't know why you'd want to install it in another brand, it won't work.
Todd
Old 05-11-2008, 10:47 AM   #7 (permalink)
just checking as there are some generic functions like code reading/reset etc that might be useful for some of the other cars i have. thanks.
Old 05-11-2008, 06:57 PM   #8 (permalink)
Member Number: 5042
Trader Rating: (31)
It may read codes for GM vehicles, mainly those made before 2007.
Todd
Page generated in 0.22734 seconds with 11 queries
