Aeroforce Technology Inc. is the innovator of OBD2 data logging in a 2 1/16' gauge technology. We have patents on the following features unique to our gauges:
1. Configurable analog inputs
2. Integrated shift light
3. Performance (0-60, 1/8 mile, 1/4 mile e.t. and speed)
You will not find another 2 1/16" OBD2 scan gauge product with these features, our imitators will have to come up with their own ideas for a change.
We are also first to developed these other unique features:
1. Ability to read and clear DTC's (Diagnostic Trouble Codes). Unless your car is totally stock and you dont' intend on modifying, this is a critical function.
2. The ability to record
and playback data on the gauge itself. Any two parameters that are selected will be recorded at up to 10 scans per second, typically about 8. This speed is critical to capture the dynamic activity of many of the parameters. Not just RPM vs one other parameter, it will playback whatever two you want. RPM is mentioned quite often because it is a great parameter to use as a reference point. If you don't know where you're getting knock, or where the A/F is lean, then that data is not as useful.
At this time no other gauge product offers these, and they are quite useful.
There is no need for a laptop, that would defeat the entire purpose of having a scan gauge. If you need to carry a laptop, use it to scan the vehicle. No gauge will replace the power and speed of it. Our product gives you the freedom to do 90% of what a latop can, without the need to carry one around.
As anyone who has used our new SRT-4 gauge can tell you, and there will be many soon, the shift light is very accurate. You'll be surprised at the lag of the stock tach.
The performance timer has been calibrated at a local drag strip, and is as accurate or more than many popular accelerometer based timers. It's been within .1 -.15 seconds of the track timer, and very consistent. It's nice to have when you can't make it to the track and want to see how that new mod really works.
You can spend a lot of money for an array of products to accomplish these same features. We've packaged them all into one little gauge. This gauge is for the serious car enthusiast, who really wants and needs to know how his car is performing.
These gauges in a similar form have been available for over a year for other makes, and a unique SRT-4 version will be available the week of April 17 from an array of vendors that will be listed on our website,
http://www.aeroforcetech.com. The SRT-4 version has a very cool start-up screen, unique to these vehicles, as well as a wide choice of display, bezel, and face color options to make your car stand out.
Retail price is $229 for a single gauges displaying any 2 of these 15 parameters:
RPM
MPH
Intake Air Temperature
Engine Coolant Temperature
Injector Pulse Width in msec.
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Manifold Pressure (vacuum/boost)
Ignition Advance
Knock Retard
Throttle Position Percentage
Engine Load
2 user configurable analog inputs**
Dual gauge sets (basically 2 singles running off of a split cable) retails for $399.
Thanks for reading!
Todd Austinson
