Old 11-29-2008, 03:48 PM   #1 (permalink)
Member Number: 60388
Default Scan Gauge code clearing
when the scangauge clears ne codes is it just clearin the code or is it more less a comp reset(like unhookin the battery)
mikes04rt4 is offline   Reply With Quote
Old 12-02-2008, 03:48 AM   #2 (permalink)
morgantj13's Avatar
Member Number: 47175
bump for answer...
Old 12-10-2008, 12:43 PM   #3 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (33)
It is just clearing the codes.
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 12-10-2008, 01:12 PM   #4 (permalink)
4TEHW's Avatar
Member Number: 5620
Todd
This. I was having issues with my cam sensor and I'd throw a code. I was able to clear it using my Scangauge removing the ~2,000RPM limiter. Life saver, for sure. Even though you can pull a fuse to clear it, being able to handle it from your car is priceless (considering when it happened I was on a very busy freeway and then later, in the middle of nowhere at night).
4TEHW is offline   Reply With Quote
Old 01-08-2009, 12:01 PM   #5 (permalink)
Member Number: 52407
I was never able to get this to work. I had poo38 which is the no cat code even though I had a cat. It would come on whenever I unplugged the sensor to work on things even though I plugged it back in.
7055 is offline   Reply With Quote
Old 01-08-2009, 12:07 PM   #6 (permalink)
4TEHW's Avatar
Member Number: 5620
You weren't able to clear it with the scan gauge? If there's an ongoing problem, the PCM will detect it and 'throw' the code again. Clearing it is only a temporary fix, unless you address the issue.
Old 01-08-2009, 08:10 PM   #7 (permalink)
It wasn't an ongoing problem, the sensor was plugged in. I just drove the car until the light turned off usually, many starts and shutdowns.
Old 01-08-2009, 08:38 PM   #8 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Is that not the one that is present on all S2/S3 kits? I should go out and check mine but there is one associated with S2/S3 that won't throw CEL and will be there after a reset, but isn't a real issue...
a853rox is offline   Reply With Quote
Old 01-09-2009, 12:26 AM   #9 (permalink)
No this was when I was all stock. It was whatever code you get if the downstream o2 isn't plugged in. What would happen is I'd unplug the o2 when working on the car, then when I plugged it in and started driving there was always that code as a result. It would go away eventually but I could never clear it with the Aeroforce. It wasn't a real issue since it doesn't affect how the car runs.
Old 01-09-2009, 04:42 PM   #10 (permalink)
Member Number: 5042
Trader Rating: (33)
Did you clear it with key on/engine off, turn ingition off, then back on? The PCM must have been immediately setting the code when you restarted the car.
Todd
Old 01-09-2009, 05:13 PM   #11 (permalink)
I just did it while the car was running, went into the DTC screen and hit the button to clear the codes. So I guess you have to do it with the car not running and the ignition on, that must have been why.
Page generated in 0.17389 seconds with 13 queries
