Old 07-23-2009, 06:44 PM   #1 (permalink)
Oskinosmee BreezyMS3's Avatar
Member Number: 72710
Default Scan gauge??
How is it used as a shift light?
MAP KPA is this manifold pressure? Can it but changed to psi?
If i clamp my MAP using a map clamp cant i look at Boost to see where it stops to check where i have it clamped?
07 Mazdaspeed 3 -Ms Intake,CS DP, gutted 2nd cat,greddy type s, CPE Standback Programmer, N2MB WotBox,Snow preformance Meth kit, 19psi= Stolen
04 Dodge Neon Srt 4-Mopar s2, Mopar s2 Coilovers,Aem Intake,Mopar Catback, Custom DP, ATP Coldpipe With Black HKS with Purple insert, AGP Wastegate, AGP Motor Mounts, Apexi turbo timer,Greddy CC, SP Meth Kit. WOT Box, DSP
Oskinosmee BreezyMS3 is offline   Reply With Quote
Old 07-23-2009, 10:20 PM   #2 (permalink)
apexcrazy's Avatar
Member Number: 24279
1 it allows you to set what rpm to trigger a pair of semi-bright leds .
2 manifold pressure can be viewed under kpa or psi .
3 Yes . If you clamp , the ECU will see resultant capped voltage , therefore the aeroforce gauge boost readings will reflect such signal modification .
_____ _____
apexcrazy is online now   Reply With Quote
Old 07-24-2009, 10:16 AM   #3 (permalink)
Thanks now how can i change it to map psi?
How do i set the shift light?
What about fan control? How can i turn them on or whatever?
Old 07-29-2009, 09:55 AM   #4 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (33)
Is this a new gauge? Whether it's new or old you can go to our website and download the appropriate manual for the gauge. Look at the back of the gauge for the version number, and go to the "manuals" section of our website and download the one for your version.
The very oldest gauges only had one manifold pressure parameter, and it read in psi. The later ones have both MAP read in kPa and inHg/psi, the latter is called "Boost/Vacuum" I believe.
See instructions for shift/warning lights
Fan control is in a menu option called "controls" and is only found on gauges made within the past 12-14 months.
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 07-30-2009, 08:36 PM   #5 (permalink)
Ok i guess i got a newer one cause i found the fan control!
Now is there a way i can get the shift light to work with the knock light?
Old 08-05-2009, 10:28 AM   #6 (permalink)
Member Number: 5042
Trader Rating: (33)
Go into the "annunciator" menu option, select rpm, enter the rpm value, select "above", exit out. It's all explained in better detail in the manual:
http://www.aeroforcetech.com/files/I...AL_rev_2_6.pdf
Todd
Page generated in 0.15087 seconds with 13 queries
