Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > Aeroforce Technology
Old 09-03-2008, 06:11 PM   #1 (permalink)
apexanimal's Avatar
Member Number: 41793
Default Recording Parameters Q
so i'm trying to record more than 2 parameters per run, but it's not happening...
here's what i have:
on the plan scan setting i have timing adv/spark adj
on the cyclic setting i have:
1. rpm/boost
2. rpm/analog(afr)
3. rpm/timing advance
4. rpm/knock retard
all of this displays properly, but as soon as i hit record it goes directly back to the basic scan mode... so it will only record the timing adv/spark adj...
help?
thanks
scott
Do it once - Do it right.
'03 GT 5spd: Stage 1+
The PTGT Webpage!!
apexanimal is offline   Reply With Quote
Old 09-04-2008, 05:40 PM   #2 (permalink)
apexanimal's Avatar
ok so i got it to record in scan mode...
but i can't look at each parameter for the entire time that it recorded...
in other words i don't have complete values for each parameter... just snipets of each...
help?!
Old 09-04-2008, 09:06 PM   #3 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (31)
help?!
What I would expect to see, and what I recall seeing when I did this once way back when, is basically a replay of what you saw in cyclic scan mode.
You're in cyclic scan, the parameters are changing as you programmed them. You then select record, and are taken back to cyclic scan except the indicator is there at the top telling you that record is enabled. Once throttle position exceeds 50% the screen inverts colors indicating that you are recording, and you are recording what is being displayed in cyclic scan. Once you fill the record buffer, the screen colors invert back again and you are still in cyclic scan. Now you go into the menu and select play, and once in you start hitting the buttons to scroll through the recorded data frames. You should see the first two parameters for a while, then these will change to the second set of parameters, etc. for as long as the recording lasts.
Hope this makes sense. Is this what you are seeing?
Todd
12.80 @ 115
Aeroforce Technology Inc.
forcefedjunkie is online now   Reply With Quote
Old 09-05-2008, 10:48 AM   #4 (permalink)
apexanimal's Avatar
^ yeah that's it...
so is there any way to record more than 2 parameters at a time?
thanks!
Old 09-06-2008, 05:06 PM   #5 (permalink)
apexanimal's Avatar
bump 4 me...
Old 09-11-2008, 01:23 PM   #6 (permalink)
Member Number: 5042
Trader Rating: (31)
It records what is being displayed, 2 parameters at a time. It does not record more than this.
Todd
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.17585 seconds with 13 queries
