Old 05-02-2008, 09:18 AM   #1 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (33)
Default Post your timing advance readings here...
I'm seeing 26-27 degrees at 20 psi running 100 octane. I'm using a stage 0 PCM.
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 05-03-2008, 12:35 AM   #2 (permalink)
Senior Moderator
N0sferatU's Avatar
Member Number: 9266
Trader Rating: (10)
I'll have better numbers when I get one for myself (it's currently on order) but when I borrowed one during one of my 1/4mi runs it showed low to mid 30s and 0.0 KR. Mods (very little) are in the sig
19psi fade to 14psi...93 octane
LC-1 Wideband showed low/mid 11s fade to 12.1 at redline
2007 Audi A4 3.2 QUATTRO
2004 Dodge SRT-4 (SOLD!)
1999 Chevy Camaro (SOLD!)
N0sferatU is offline   Reply With Quote
Old 05-04-2008, 01:34 AM   #3 (permalink)
catlin987987's Avatar
Member Number: 55516
Stage 2 w/ toys
no toybox
94 oct w/ ethanol
BFMIC
borla
16 spike 14 hold
K&N CAI
timing 29-33
1 KR
catlin987987 is offline   Reply With Quote
Old 05-04-2008, 01:39 AM   #4 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
Stage 3R...
Max recorded is 34.5 degrees in HOM with 110 leaded
Old 08-21-2008, 12:34 AM   #5 (permalink)
Novak94's Avatar
Member Number: 45523
Stage 3R + Basic Bolt-ons
23psi spike 20psi hold
93 octane
A/F 11.4 @ Redline
24-25* Timing
Old 08-21-2008, 03:18 AM   #6 (permalink)
RiVal's Avatar
Member Number: 51024
stock turbo stage0
91oct mods in sig
on 20.8psi spike 26-29deg
34-37.5 deg
on boost drop to redline 14.3psi
i have actually seen 38deg at redline
100% meth m3 nozzle with 91oct
i have dual scangauges to monitor
-SMOKE-EM-UP- Eatin V8's spit on 6's and sh**in on any other
**OLD ET(2008): 12.715 @ 110.686 2.038 60ft
91/meth Street tires**
best Trap- 111.3
best 60ft- 1.972 street tires
**E85 NUMBERS coming SOON**
RiVal is offline   Reply With Quote
Old 08-21-2008, 06:54 AM   #7 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
S3R with toys, and bolt ons, pcm controlled I see mid 20s HOM off, and mid 30s Hom on!
I'll have updated numbers soon I added a 255 pump, safc2, and ptp s3wga off pcm controlled boost!
S256 non extended tip F/IC tuned by Aaronneon
11.88@116 1.74 60'
Old 08-21-2008, 08:40 AM   #8 (permalink)
Member Number: 13142
stage1 ecu, 50 trim @22psi 91 octane, 21-24 Degrees @ redline with 2-4kr
spraying 100% meth through a m10 nozzle spraying right before the TB
cooler days I see 0-1kr with 26 degrees or timing toward redline. hotter days i've seen 19-20 degrees with 6 degrees of kr. still trying to find that sweet spot with the meth system, goign to try some water in teh mix.
seltech is offline   Reply With Quote
Old 08-21-2008, 11:31 AM   #9 (permalink)
Senior Moderator
N0sferatU's Avatar
Member Number: 9266
Trader Rating: (10)
I swear I'm a freak. Finally readjusted my clamp since moving back to Florida.
93 pump gas
stock fuel system
stage 0
19psi fade to 14psi
AFR typically mid 11s at redline (high 11s mid range)
32.5 to 33.0 deg @ redline
Intake Temps (post FMIC) 95-100deg (yay for South Florida)
It's usually like this
4000rpm 26-27
5000rpm it's 30
steadily climbs to 33.0 @ redline.
Old 08-27-2008, 03:22 PM   #10 (permalink)
gq4life's Avatar
Member Number: 10297
i so need this guage
Old 08-27-2008, 06:22 PM   #11 (permalink)
cokey's Avatar
Member Number: 17219
Which guage are ya using and where can I get one?
cokey is offline   Reply With Quote
Old 08-27-2008, 06:31 PM   #12 (permalink)
Freaky's Avatar
Member Number: 47525
so i'm new to the timing thing . not sure what is normal what is good an what sucks . any help ?
Freaky is offline   Reply With Quote
Old 08-28-2008, 02:50 PM   #13 (permalink)
gq4life's Avatar
i dont have one of the Aeroforce guages.. i want one..
i got wideband O2, oil pressure ( in case oil pump takes a dump), 30psi boost guage, oil temp gauge but i want to sell that been meanin to.. its brand new.. never hooked up..
Old 08-28-2008, 02:52 PM   #14 (permalink)
gq4life's Avatar
ok.. im just pulling numbers out my ass but..
i think 25-28 is bout average.. 30 over good..
now of course u got to make sure u have no knock.
my timing is PCM controlled.. Ive seen when I use to log with my piggy back 30+.. i think I had meth inj already though
Old 08-28-2008, 04:25 PM   #15 (permalink)
nickobsrt4's Avatar
Member Number: 33834
Trader Rating: (20)
im getting about 16 to 17* of timing i have a stg 3 pcm ms3 44lb wheel bc stg 2 cams full boltons untuned non pcm boost its on a ptp stg 3 wg
nickobsrt4 is offline   Reply With Quote
Page generated in 0.17973 seconds with 13 queries
