Quote: Originally Posted by
catlin987987
its called vacuum
Did you notice that I said "When boost goes over 21.4 psi" in my first post?
forcefedjunkie
The stock MAP sensor will only read up to around 22 psi, anything higher and the PCM does not send a valid response. To learn more do a search in this forum, there have been other in depth discussions.
The easy way around this is to connect an external 3 bar MAP to an analog input, then you can read boost up to 29 psi. If you want to go higher than that, we also have 7 bar MAP sensors.
Todd
I got Mopar Stage 3 on my car, so the MAP sensor should be 3 bar, that's why I thought it was weird not to get the good reading.
*EDIT*: Okay, I just read that it is caused by the PCM -> OBD2 port -> gauge communication. I suppose that I could splice the output wire from the S3 MAP sensor and plug it to one of the analog inputs of the gauge. Anyway, I'll get a 30 psi gauge soon, so that won't be an issue anymore. Thanks forcefedjunkie!
