Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Aeroforce Technology
Old 06-13-2008, 01:15 AM   #1 (permalink)
Member Number: 45523
Default Knock question?
Hey guys i recently put in a duel setup in my srt and have been lovin it, i have one question about the "knock" displays. What is the differences between them?
I have he ability to look at the following:
-Knock Ret (which is basically standard knock measurements )
-Knock volt (which is the voltage from the sensor)
-LT Knock ???
-ST Knock ???
-Fuel Knock ???
Could one of you guys do some explaining for me, Thanks
S3R
Old 06-13-2008, 08:09 AM   #2 (permalink)
Dragvan's Avatar
Member Number: 48018
I guess I need to get my gauge upgraded I can only see Knock retard/ knock volt. I would think the knock retard is what you need to monitor. I was at the track last night recourdind KR and boost then KR and rpm and found that I was geting 1.5kr at 5400/14psi 4.0 kr at 5600/13.5 psi? I think by the time you see the retart the knock has already happened. I was spiking 18 fall to 13.5 when I see 1.5to4.0 kr. If I lower the spick to 16.5 fall to 14 no knock but at 5400 sam 14 psi and 5600 at 14 psi no knock. So I think the knock happended at a lower rpm and where it was at a higher psi the the comp retards to save the motor. Anyway ya I think KR is what you need to moniter.
1988...Chrysler..Lebaron....2.2L...Turbo....9.01 14psi DRs
1990...Dodge....Caravan....2.2L...Turbo....9.50 14psi DRs
2004...Dodge....Ram 1500..5.7L...N.A.......9.28 SC 91 tune
2005...Dodge....SRT-4.......2.4L...Turbo....8.82 stock DRs
2005...PT Cruiser.2.4L...Turbo....9.36 stock
Dragvan is offline   Reply With Quote
Old 06-14-2008, 02:00 PM   #3 (permalink)
Elected Moderator
N0sferatU's Avatar
Member Number: 9266
Clarification on reading knock from gauge
VERY TOP POST IN THE STICKIES
Search much before posting? I just asked this 2 weeks ago
2004 Dodge SRT-4
Stock Turbo, Stock Fuel System, Street Tires
60': 2.11
1/4mi: 13.29 @ 110.51mph
N0sferatU is offline   Reply With Quote
Page generated in 0.16433 seconds with 11 queries
