Old 01-07-2009, 10:51 PM   #1 (permalink)
Member Number: 52407
Default How much knock volts correlates to how much knock retard?
Anybody know? For example 1 volt of knock is how much knock retard? Or is there even a direct correlation? I just did some pulls recording with the scanguage but I thought I had it on Knock Retard when it fact it was on Knock Volts. It did not occur to me until I looked down and saw knock at idle.
7055 is offline   Reply With Quote
Old 01-08-2009, 09:52 AM   #2 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (33)
Generally speaking the higher the knock volts the more knock retard, but it's not that simple. The knock sensor is a microphone that picks up a lot of things other than cylinder knock. The PCM has filters that determine what is truely knock and in turn calculate the proper amount of spark retard to eliminate it.
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 01-08-2009, 09:59 AM   #3 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
I've heard from reputable tuners that anything under 3.0* KR is not actual knock. Don't know if this is true or not.
Old 01-08-2009, 11:52 AM   #4 (permalink)
I figured it might not be that simple, thanks for the responses.
3KR really? Or 3 volts?
Old 01-08-2009, 12:00 PM   #5 (permalink)
Philth's Avatar
Trader Rating: (29)
3.0* knock retard. I don't mess with the volts reference usually.
Old 01-08-2009, 12:23 PM   #6 (permalink)
Monster's Avatar
Member Number: 48761
Trader Rating: (68)
How much timing is retarded for every count that the pcm thinks is knock. Like is it 1 deg for every count or is it higher then that?
www.pt-performance.com
Tunes send your request to tunes@pt-performance.com
Old 01-08-2009, 12:26 PM   #7 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
theres a crystal in the knock sensor that vibrates and creates an electrical signal..it also picks up a lot of noise. the noise is linear with rpm so a filter is used to wash out the noise so what you see is a result of knock voltage minus the correction table= actual knock on the sensor it will pull back timing according to what it sees. many things affect it such as solid mounts etc.
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 01-08-2009, 12:36 PM   #8 (permalink)
Monster's Avatar
Trader Rating: (68)
But is there a definite correlation between the amount of "kr" the pcm shows and the amount of timing pulled? I understand false knock is filtered but Ive always wondered if its 1 deg of timing pulled = 1kr and 2kr means 2 deg timing pulled or if 1kr could actually be 2 or 3 deg being pulled do you follow?
Old 01-08-2009, 12:42 PM   #9 (permalink)
Trader Rating: (59)
what im saying is there is no direction correlation between voltage and timing pulled. the stock cal is set for a stock motor with stock parts if you put solid mounts and start changing internals you change the natural frequency of the engine.the amount of knock pulled depends on what the ecu has learned and the amount of timing pulled in degrees and fuel added is whatever the ecu has learned. i dont know what the min/max threshold is or or the hysterisis is..dont know if anyone does except for maybe guys who have unlocked the pcm
Old 01-08-2009, 12:43 PM   #10 (permalink)
Trader Rating: (59)
so 1 volt of knock im pretty sure would equate to a whole heck of a lot more timing pulled than 1 degree.if 2 volts knock was 2 degrees pull there would be an awful high pile of cast iron laying around
Old 01-08-2009, 12:47 PM   #11 (permalink)
Monster's Avatar
Trader Rating: (68)
I follow you I generally was subtracting 1 deg of timing for every count of knock I was getting but 1 deg didnt always solve the problem... Interesting ... thanks
Old 01-09-2009, 04:37 PM   #12 (permalink)
Member Number: 5042
Trader Rating: (33)
Knock retard is in degrees, so if you see "1", that is one degree of advance removed. Knock counts is something different, I'm only familiar with this in regards to GM vehicles. It's a measure of the length and severity of knock, which plays a role in how much timing to take back.
Todd
Old 01-13-2009, 11:06 PM   #13 (permalink)
Member Number: 57123
i did a pull looking at both settings. Knock retard and knock volts.
I did a pull and it read 8 knock retard
then again using knock volts and it was 1
So do the MATH...
my .02
HP61(Blown),Porfueler, Mapclamp,Greddy Profec II EBC, AGP Hard Pipes, Synchronic BOV, MPX BFMIC, Race motor mount inserts, MSD Cap and Wires, Needswings Downpipe w/cut out, AEM Wideband, AGP CAI.
Best time on Garrett 50 trim 12.3 at 113MPH.Elevation 4,XXX.
on 26PSI. Boost leak maybe?
Garrett 50 trim SOLD
20g turbo kit SOLD.........
up_in_boost is offline   Reply With Quote
Old 01-14-2009, 11:32 AM   #14 (permalink)
My math says your engine's going to blow up
Old 01-14-2009, 01:39 PM   #15 (permalink)
Thats what i thought
Compression check shows different.....
Page generated in 0.18170 seconds with 13 queries
