Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > Aeroforce Technology
Old 04-29-2008, 01:19 PM   #1 (permalink)
Netou's Avatar
Member Number: 29372
Trader Rating: (65)
Default How to make air fan turn on, help?!
I have the new version of this scan gauge with the function to turn on the fan...I've been having it for a month now and still cant figure out how to turn the fan on from the gauge.
Any help or advice on how to work this?!
Netou is offline   Reply With Quote
Old 05-01-2008, 07:30 PM   #2 (permalink)
Netou's Avatar
Trader Rating: (65)
Old 05-02-2008, 10:38 AM   #3 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (31)
Is it not working or you don't know how to do it? Assuming the latter you go into the menu, scroll to the end where it says "controls". Select this, you'll see a screen that has high and low speed on, and fan off. Select either hi or low and the fan should turn on. To turn it off go back to controls and select fan off.
Todd
12.80 @ 115
Aeroforce Technology Inc.
forcefedjunkie is online now   Reply With Quote
Old 05-02-2008, 08:20 PM   #4 (permalink)
Dragvan's Avatar
Member Number: 48018
So you cant set a temp to turn on? Starting to wonder if Im going to upgrade my gauge I thought you could set on/off temp.
1988...Chrysler..Lebaron....2.2L...Turbo....9.01 14psi DRs
1990...Dodge....Caravan....2.2L...Turbo....9.50 14psi DRs
2004...Dodge....Ram 1500..5.7L...N.A.......9.28 SC 91 tune
2005...Dodge....SRT-4.......2.4L...Turbo....8.82 stock DRs
Dragvan is offline   Reply With Quote
Old 05-02-2008, 08:40 PM   #5 (permalink)
Netou's Avatar
Trader Rating: (65)
Todd
That's exactly what I did, several times, but the 2nd fan never turns on. I placed my gauge on another SRT and it didnt work neither. Everything else on the gauge works flaulesly. Guess I'll just mess with it again tonight...weird. Thanks for the help, though.
Old 05-07-2008, 08:57 PM   #6 (permalink)
Member Number: 5042
Trader Rating: (31)
The gauge gives you manual control over the cooling fan, it's not a PCM reflash tool.
Todd
Old 05-07-2008, 09:01 PM   #7 (permalink)
Member Number: 5042
Trader Rating: (31)
I still don't understand, in your first post you said you can't get the fan function to work, then you said the second fan won't turn on. What about the first fan? You should be able to turn on at least one of the fans.
Todd
Old 05-11-2008, 02:25 PM   #8 (permalink)
Netou's Avatar
Trader Rating: (65)
Todd
Todd,
I got it to work last night...somehow I had to turn the fan option to off then to low then to high and it worked. I had to do it in a sequence or else it wont go to high fan mode.
Greatly appreciate ur replies though.
Old 05-11-2008, 04:52 PM   #9 (permalink)
Member Number: 5042
Trader Rating: (31)
Todd,
Your car is a 2003? That's odd, I have not heard of that before. I'll keep that in mind if it ever comes up again.
Todd
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.18803 seconds with 13 queries
