Old 12-26-2007, 03:43 PM   #16 (permalink)
VampOfVegas's Avatar
Member Number: 38215
Trader Rating: (76)
For correction I put 90. That calculates the 10%.
VampOfVegas is offline   Reply With Quote
Old 12-26-2007, 03:44 PM   #17 (permalink)
Trader Rating: (76)
Quote: Originally Posted by 4DRVIPER View Post
Yeah they read about 10% high. I register 492 @ 28psi, so figure 450-460ish.
492-10% = 442.something
Old 12-26-2007, 03:54 PM   #18 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (167)
hmm, so it's only off 10%?
at ~21-22 psi on my 3147 my HP usually reads usually between 200-220
Old 12-30-2007, 04:21 PM   #19 (permalink)
lblackneon's Avatar
Member Number: 56748
Trader Rating: (21)
I love my Aeroforce gauge. What does the Aeroforce measure the hp by? Is it Hp at the crank or whp?
2004 N. SRT-4: T04Z etc.
FS: Brand New Crank
http://www.srtforums.com/forums/f27/...kshaft-543361/
2000 Dodge Neon ES: Downgraded close to stock.
lblackneon is offline   Reply With Quote
Old 12-30-2007, 04:40 PM   #20 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (13)
So I ended up dynoing 391 whp. dynojet. So 10% seems pretty accurate
11.9@117 so far.
Wiseman - Just cuz someone else has a fast car with the same parts as you, doesn't mean your car is fast.
Work harder, millions of people on welfare are depending on you.
srt4geezer is offline   Reply With Quote
Old 12-30-2007, 08:42 PM   #21 (permalink)
lblackneon's Avatar
Trader Rating: (21)
Well???
Old 12-31-2007, 09:46 AM   #22 (permalink)
blacksin's Avatar
Member Number: 39845
Trader Rating: (18)
Well???
WELL... It would obviously have to be at the crank... there's no way for the gauge to ACCURATELY calculate WHP if it's not monitoring the wheels, just the engine PCM from the OBD port. If you want an estimate of the WHP, set the HP option to 90 since it reads 10% high and then take off an additional 15% for the FWD crank-to-wheel HP adjustment ratio.
Custom CAI + MOPAR: Stage 2 w/ toys, Borla Cat-back exhaust, STS w/ boogers, S1 springs, RB1 w/ IPOD kit N2MB: Toybox 2.0, Code Scrubber Aeroforce Technology: Scan Gauge MaxxFab: 3" downpipe Forward Motion: E1, wga
blacksin is offline   Reply With Quote
Old 01-01-2008, 01:51 AM   #23 (permalink)
lblackneon's Avatar
Trader Rating: (21)
That's what I thought. I don't see how it could calculate the hp at the crank either.
Thanks.
Old 01-01-2008, 01:56 AM   #24 (permalink)
blacksin's Avatar
Trader Rating: (18)
That's what I thought. I don't see how it could calculate the hp at the wheels either.
Thanks.
Corrected for ya.
Old 01-01-2008, 10:04 PM   #25 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (33)
At WOT it only reads 200-220? You must be using a DTEC or map clamp, which is throwing off the calculation a lot. Is the HP correction factor in the gauge set at 100?
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 01-07-2008, 05:51 PM   #26 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
Todd
i have an safc .... not sure about the HP correction factor, i'll have to check the next time i'm in the car
and yes, it reads 200-220 at wot ... i know it has a lot more than that, considering i trapped 118 with less power then i have now
Old 01-07-2008, 08:10 PM   #27 (permalink)
killerSRT's Avatar
Member Number: 34265
Trader Rating: (80)
Yea you are tricking the computer into thinking you have less boost, so the gauge will be off. If you go to manifold psi and go at full boost, im sure you will be at less than 20. At 20-21psi my gauge reads like 12psi Once i get my AGP PCM flash and use a 3-bar map sensor to start showing the computer my REAL boost, i shall be a happy man
Edit: My 50 trim is just like yours. I was reading 2xx in 3rd gear at WOT...i was thinking something may have been a little off
Member #13 of the "Ramenite Noodler"
killerSRT is offline   Reply With Quote
Old 01-16-2009, 08:14 AM   #28 (permalink)
SRToad4's Avatar
Member Number: 61889
Seems about right, my scan gauge read 333 during a third gear pull with a map clamp....
333 * .9 = 299.7
299.7 * .85 = 255
I dyno'd 245/306, so it seems pretty accurate! I did a third gear pull on the dyno (should've done 4th!!)
I'll be back with the AGP 50 though
Tuned by Tony @ UMS Tuning
390whp/380tq @ 21.5psi / 91 + Meth
SRToad4 is offline   Reply With Quote
Page generated in 0.22013 seconds with 13 queries
