i put down 298 on 91oct. with stage 2 w/o, map clamp(12.2 spike, and 10.8 at redline, ptp wga(21spike, 14.5 hold), MPx FMIC, needs wings v5 (cut-out closed) mated with mopar/borla cat back, and an AEM short ram intake. how accurate is this?
they read about 10% high.
nice, so about 270?
05 Flame RED
MAYHEM MOTORSPORTS
Yeah they read about 10% high. I register 492 @ 28psi, so figure 450-460ish.
Quote: Originally Posted by HIERGLYPHICS3030
nice, so about 270?
i think i would put down more but i had my 2 stock wheels with drag radials in the trunk and 2 buddies in my car, about 200+ each.
nice, did you ever get that idle problem sorted out?
nice, so about 270?
Not really, but you know what? I think I may have a lifted head. The problem I have been having with this mis under sligt throttle could easily be mistaken for a bent valve. Fels the same way, which is why I am now leaning towards a lifted head. Occassional white smoke, etc. and even before the twins I was over 22 psi, so it is a possibility. Might have to have the head taken off and decked to ensure a good seal. These cars have horrible tolerances on the head.
nice, so about 270?
do you have an 05? i remember something about a recall on 05's with bent valves or something.
nice, so about 270?
Yeah, I read bout that a while ago too. I have an 04. I am pretty sure it int a bent valve, compression test was 159 160 160 160 when I checked.
nice, so about 270?
10% sounds like it s/b correct if it's at the crank... I have a "stock" S2 with MOPAR cat-back... I've hit 333 hp during a third gear pull. 10% of that is 303 hp, and take 15% of that for the FWD WHP percentage.. so that's 255.85 at the wheels.. which is somewhat around the MOPAR S2 rating of 265.. also my fuel mileage on the gauge is about 10% low. Gotta set the adjustment to 90 on the guage one I get it reflashed.
