Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Aeroforce Technology
Old 05-10-2008, 11:11 AM   #1 (permalink)
Elected Moderator
N0sferatU's Avatar
Member Number: 9266
Default How accurate...
I just picked up a brand new Aerometer (mechanical) boost gauge and it reads 19 fade to 14psi yet the aeroforce reads 16.4psi fade to around 11.8psi (which seems rather odd and low).
Which is gonna be right?
BTW I like the Performance part it seems spot on (see sig) it got me 13.50 @ 106 and an 8.8 @ 85mph and 0-60 in 5.4sec (can't launch on street tires for crap)
2004 Dodge SRT-4
Stock Turbo, Stock Fuel System, Street Tires
60': 2.11
1/4mi: 13.29 @ 110.51mph
N0sferatU is offline   Reply With Quote
Old 05-11-2008, 10:10 AM   #2 (permalink)
$PK$'s Avatar
Member Number: 47676
I would think the scangauge is rather accurate compared to a needle with tiny markings. The scangauge reads whatever the pcm is reading. I was adjusting my buddys agp wga on his 05 with stock pcm and I used the scangauge to see the boost. It was way to hard using the needle gauge when it rattles and shakes and stuff.
401whp 419wtq on pump gas tuned by Jannetty Racing Enterprise
$PK$ is offline   Reply With Quote
Old 05-11-2008, 06:56 PM   #3 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (30)
Yes, the stock MAP sensor is pretty accurate, within about 0.1 psi. What are you seeing with key on engine off for boost?
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 08-27-2008, 01:45 PM   #4 (permalink)
Tony35's Avatar
Member Number: 61633
Trader Rating: (13)
well if ur clamping then the scangauge is goin to read what u clamped it at. so i think the autometer is def more accurate if ur clamping or have a piggyback of some sort.
Mopar CAI, MSD Ignition, Stage 2 W/O Toys, 3" catless Downpipe, Mopar Catback exhaust, Prothane Inserts, Devils Own PRogressive Alcohol Injection, 57mm Ported Throttle body and spacer, AGP FMIC, DTEC FC, DCR Ported Intake Mani.
Tony35 is offline   Reply With Quote
Page generated in 0.14791 seconds with 11 queries
