Old 08-27-2009, 11:29 AM   #1 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
Default Getting Aeroforce into stock boost gauge location?
Ive been running the Aeroforce for some time (thumbs up!) but every couple months I need to readjust my electrical tape I wraped around it to make it a tight fit in the holder. I guess the electrical tape stretches when the car sits.
Anyways, is there a better solution?
Thanks
2.0L SOHC - 400whp 11/11/04 - still shooting for 450whp+
Check out my mods and pics here
Roach is offline   Reply With Quote
Old 08-27-2009, 06:40 PM   #2 (permalink)
Member Number: 36585
yes...i never understood why aeroforce didnt make it a true 2/16 gauge...anyway, there is a write up somewhere on here about this.. i use 24 gauge sheetmetal cut 2" by 1" drilled holes to match up the scangauge, and the pod holes..then you need 2 bolts and nuts to go from the support (the sheetmetal) to the pod holes. secure the mount to the scangauge then use the bolts to secure the pod to the sheetmetal mount.. sounds hella confusing, i know, but i cant find the link to the how-to. a buddy put the scangauge into the pod, off the dash, laid it flat onto a table, centered up, and squeezed a tube of black rtv between gauge and pod, let it dry for a day and reinstalled it...kinda ghetto but holds fine..
just-a-neon is offline   Reply With Quote
Old 08-28-2009, 02:20 PM   #3 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
I kinda like it not being bolted in, so I can take it out easily if need to. Just thought something between electrical tape and the sheet metal method would be best. Like a plastic ring to make the inner bezel thicker to slide in there.... *shrug*
Old 08-28-2009, 07:55 PM   #4 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (33)
Huh? It is a 2 1/16" gauge. Every manufacturer will have slightly different tolerances. Talk to Mustang guys trying to fit Autometer gauges into Speed of Sound pods, the Autometers are slightly larger than 2 1/16" and won't fit without trimming the pod.
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 08-30-2009, 09:01 AM   #5 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
Todd
Todd what do you suggest to customers? Thanks
Old 08-30-2009, 11:34 PM   #6 (permalink)
Member Number: 5042
Trader Rating: (33)
What I've always done with any gauge is wrap tape around the housing if needed to make it fit snugly. I do not like using mounting brackets, makes it too hard to remove. In my case on the SRT4, I have our Interceptors mounted in a dual a-pillar pod, they fit perfectly without needing anything additional.
Todd
Old 08-30-2009, 11:36 PM   #7 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
electrical tape?
Old 08-30-2009, 11:56 PM   #8 (permalink)
planetb's Avatar
Member Number: 4909
I got my Aeroforce in a boost pod. I cut the back brace out with a rotozip. moved it forward. Glued in back in and then took fiberglass resin and cut some old black fleece blanket ( fiberglass resin needs to bond too something) and cleaned up the mount a little (made is stronger). drilled holes for the 2 screws on the back of the aeroforce. filed the opening a little a using the resin to make it a little tighter fit for the gauge. all fits nice now I should have took pics of that build. oh well. Gotta take it out soon to tweak it. maybe I'll take some pics of it soon. I missed my measurement by like 1mm.. so there is a little gap between the gauge and pod..
Pentax K10D - AF-S/C Pentax SMC DA 18-55mm
2004 Flame Red SRT-4 - K&N,Kicker,Maddog 58%, 10MM wires and Denso Plugs, SSW Inferno(hyper Black) wheels, SuperBeast IC
2007 Dodge Nitro Silver
1999 Ram 2500 Cummins.
1987 Shelby Lancer #382 - 88 T2/s60,Koni's,Alum Fly
planetb is offline   Reply With Quote
Old 08-31-2009, 12:02 PM   #9 (permalink)
Member Number: 2005
Trader Rating: (24)
Quote: Originally Posted by Roach View Post
electrical tape?
Try the blue painters masking tape. That is what I used, it has a little texture to it and it won't heat up and get all gooey when the car gets hot inside.
I have had mine this way for a while now and I have not had a single problem with it moving.
Greg 04-SRT4
Greg_04-SRT4 is offline   Reply With Quote
Old 08-31-2009, 08:29 PM   #10 (permalink)
Member Number: 5042
Trader Rating: (33)
I've used that blue masking tape as well. Regular masking tape works too.
Todd
Old 08-31-2009, 10:24 PM   #11 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
Yeh ill switch it over this weekend. Hope its not too gooey when I take it off lol
Old 09-03-2009, 08:51 PM   #12 (permalink)
BlingWs6's Avatar
Member Number: 28892
Pics of Aeroforce gauge install in stock pod
here is an old thread, but my pics are still working. All I did was wrap a rubber band around the scanguage.. it was still easily removable, but never once moved when it was 'installed" in the stock pod..
BlingWs6 is offline   Reply With Quote
Page generated in 0.17748 seconds with 13 queries
