Old 03-28-2009, 09:18 PM   #1 (permalink)
gq4life's Avatar
Member Number: 10297
Default this gauge rock!
don't know how u invented this but it is awesome.. being able to watch knock & ignition adv is great.. checked out horsepower today & got to 450 something before I let off & it was still climbing before I let off.. going to get car dynoed & see how on it is.. stay tuned to find out..
Old 03-29-2009, 01:33 AM   #2 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
By far one of the best things ever to come out for a car!
S256 non extended tip F/IC tuned by Aaronneon
11.88@116 1.74 60'
Old 03-29-2009, 01:55 AM   #3 (permalink)
gq4life's Avatar
so is horsepower accurate. I have taller tires so I'm sure that effects readings.
reading prob low cuz I'm going faster then what ecu thinks.
I'm about to hook my af up to it so I can record it over rpms..
Old 03-29-2009, 03:08 PM   #4 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Yeah it's freaking awesome. I still havent' figured out how to control the fans though
or 16 whatev
Old 03-29-2009, 04:29 PM   #5 (permalink)
apexcrazy's Avatar
Member Number: 24279
as I have heard , the HP values run about 10% high on a STOCK setup . That is to say if the gauge shows a HP of 300 , your probably making 270 something at the wheels . There is a correction funtion , I believe , so once you dyno you can calibrate it to an extent .
And yes It is a very valuable tool . Absolutley invaluable if you are running the PRP software because SCT havent released thier datalog funtionality yet .
Thanks Aeroforce
_____ _____
apexcrazy is offline   Reply With Quote
Old 03-29-2009, 06:39 PM   #6 (permalink)
Trader Rating: (30)
Hold both buttons in, scroll thru the menu, its in there!
Old 03-29-2009, 07:02 PM   #7 (permalink)
hercfe's Avatar
Member Number: 19255
is there new software for these or something? i bought mine used, and i can't monitor horsepower or anything like that...
hercfe is offline   Reply With Quote
Old 03-29-2009, 08:05 PM   #8 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (33)
You have a very old version if hp is not on there. The latest version is V2.6, found on the back of the gauge. HP has been on the gauge since 2006. Versions before this have a different naming nomenclature, like SR201E, using letters rather than a version number.
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 03-29-2009, 09:07 PM   #9 (permalink)
Member Number: 61830
Trader Rating: (17)
make sure you have it selected to scan. Its the very last one on the check box when you select which paramiters to scan.
Spaz_22 is offline   Reply With Quote
Old 03-29-2009, 11:16 PM   #10 (permalink)
gq4life's Avatar
I don't use scan.. I like to watch knock retard & ign adv..so far best spraying meth 34.5* & 1 KR for a second then 0KR for restI think my HP low cuz my tires r taller then stock by more then half an inch.
Old 03-30-2009, 02:14 PM   #11 (permalink)
hercfe's Avatar
Todd
thanks. any way to update the software or firmware?
Old 04-03-2009, 04:14 AM   #12 (permalink)
Trader Rating: (17)
If you are only watching 2 parameters then you are scanning. Cycling is were the gauge cycles through each parameter selected. When you are scanning, you select which parameters to watch, you can select which parameters you want to scroll though in the setup screen. Make sure you have hp selected, it is the very last parameter to select in the setup screen.
Old 04-03-2009, 06:14 AM   #13 (permalink)
gq4life's Avatar
oh.. scan stays on 2 u pick. cyclic cycles thrus. ok cool..yea I got HP turned on..but is my HP & MPG off if my tires taller then factory..though going to calibrate HP when I dyno car
Old 04-05-2009, 04:08 PM   #14 (permalink)
Member Number: 5042
Trader Rating: (33)
It's explained here:
Aeroforce Technology Inc Technical Forums :: View topic - Firmware upgrades
Todd
Page generated in 0.18273 seconds with 13 queries
