Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Aeroforce Technology
Old 05-13-2008, 09:50 PM   #1 (permalink)
Member Number: 31650
Default engine flow
i tried to record flow ...but it seem's it is a calculated value since i don't see it when i play it back
is the value hard to calculate ?? if i could know what value to use maybe i could just put it in excel and have the calculated value ??
Not stock anymore
Old 05-16-2008, 06:38 PM   #2 (permalink)
stageII's Avatar
Member Number: 32588
Trader Rating: (33)
i have been waitting for todd to answer this can you explain a little more and then maybe i can help
IF YOU GOT THE MONEY I WILL PLAY
SOME BEAT THERE CAR TO HIT 11'S I DRIVE NORMAL
All DCR:motor,Head,oil system,intake mani,throttle body/spacer,Water injection,Battery kit,Greddy boost control,Crower stage 2 cams,fidenza cam gears
Turbonetics DBB 50trim, lots more
GRANNY SHIFTING
New Best1/411.60 at 124.75 mph UNTUNED26.0psi
Best1/8 7.69 at 94.38 mph UNTUNED22psi
stageII is offline   Reply With Quote
Old 05-16-2008, 10:22 PM   #3 (permalink)
i just want to know wich X * Y equal flow
if it is not a secret recipe
i would then be good to record X and Y and make my own calculation
Old 05-17-2008, 06:19 AM   #4 (permalink)
stageII's Avatar
Trader Rating: (33)
you will have to wait for todd to answer that one i am not sure on that. sorry i cant help i will inform todd to take a look at what you are asking.
Old 05-24-2008, 09:36 PM   #5 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (27)
Engine flow is a PCM calculation, not one of ours. This is assuming you have firmware 2.4, or are in platform 1 of version 2.5.
If you are mistakenly in platform 2 of version 2.5, then yes, this is a calculation done in the gauge. Go back to platform 1 and you can log engine air flow.
If you have V2.4, or are in platform 1 and still can't log air flow contact service@aeroforcetech.com and they will look into it.
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 05-25-2008, 12:05 AM   #6 (permalink)
Todd
can you give me a refresher on how to get the info on wich version i have ??
Old 06-03-2008, 07:46 AM   #7 (permalink)
Member Number: 5042
Trader Rating: (27)
It should be on the part number on the back of the gauge, or look at the quick start manual that came with the gauge, it will have the FW version written at the top.
Todd
Page generated in 0.26677 seconds with 11 queries
