cam position degrees
Ok, when i first installed my scan gauge the cam pos deg function read 0.0. A couple of weeks ago I was scrolling through the gauge and noticed it read 29.5 on cam pos deg. I didn't sweat it because the car was still running correctly and there was no knock or anything. Then today i ran it at the track and was scrolling through the gauge again sitting in the staging lanes and noticed that it now reads 62.0 on cam pos deg and the gauge is also showing .5-1 on ST knock which isn't enough to worry about. I would rather see none but I'm not going to sweat the knock. I need to get tuned ASAP. I'm only running 9 psi on the stock fuel system with the AGP 3147 kit. Basically I just need to know what this means and should i worry about it.
Mods
AGP 3147 kit/Turbonetics Evo wga/AGP log style manifold ported/DCR ported TB/Needswings v5 with electric cutout/DSP/DW 650cc injectors/AGP cold air intake/SS Autochrome BFMIC/ACT 6 puck clutch and prolite flywheel/Megan Racing Coilovers/WOT Box/FTP solid MM/Prothane lower control bushings//
