Old 02-27-2008, 02:08 PM   #16 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (33)
Quote: Originally Posted by NoisufnoC View Post
bumping this up...
i've got the turboxs tuner pro wideband which has a 0-5v output where i can set the max and min for AFR. assuming I set the min for 10 and the max for 20 like the AEM UEGO i should be able to use the same settings...right?
Yes.
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 04-05-2008, 07:17 PM   #17 (permalink)
SkittlePower's Avatar
Member Number: 37724
Trader Rating: (50)
i have an autometer wideband, which its analog output is 0-4v, will that work on the pro gauge? and if so, how would i hook it up and what correction factor would i need?
SkittlePower is offline   Reply With Quote
Old 08-24-2008, 05:19 PM   #18 (permalink)
Moparahollic05's Avatar
Member Number: 54793
I just wired up one of the analog inputs with the aem, super easy....
Great gauge
293HP, 349TQ
8.258@87 1/8 mile pass
12.925@108 1/4 mile pass
Moparahollic05 is offline   Reply With Quote
Old 08-31-2008, 09:50 PM   #19 (permalink)
Member Number: 5042
Trader Rating: (33)
Yes, it will work, I've had others confirm this. I don't know the specifics of the autometer unit. You need to refer to its instructions to find the correct ouput wire to connect to one of the Interceptor's inputs. In the Autometer instructions it will also state the output calibration, something like 0v = 10 A/F ratio, 4v = 20 A/F ratio (this is just a guess, most likely not the actual calibration). From there determine the slope and intercept (use your math skilz!) In the example I just gave, slope will be 2.5, and intercept will be 10. In other words, voltage x 2.5 + 10 = A/F ratio. There is another example in the Interceptor user manual using the AEM Uego as an example of determining slope and intercept.
Hope this helps.
Todd
Old 08-31-2008, 11:34 PM   #20 (permalink)
Trader Rating: (50)
Hope this helps.
Todd
thats perfect. i bought my scan gauge used, and now i finally have the analog input cable on the way, so ill wire it up and do some real tuning in the next few weeks. thanks a lot
Old 03-01-2009, 03:38 PM   #21 (permalink)
Trader Rating: (50)
one more question, theres 3 wires on the input cable....what is the third one for? and i have a fuel pressure sending unit from you which also has 3 wires, how would i hook the two up?
Old 11-03-2009, 12:08 AM   #22 (permalink)
Member Number: 31038
Trader Rating: (49)
So what would I need to be able to display fuel pressure on the the scan gauge? I really don't want to spend $180 on a damn fuel pressure gauge...
Would I just need a sending unit for the fuel rail? If so which one do you recommend? Thanks.
raul-01 is offline   Reply With Quote
Old 11-03-2009, 10:44 AM   #23 (permalink)
Member Number: 5042
Trader Rating: (33)
Our sensor is $65 and works well with the Interceptor (obviously ) Depending on your fuel system you may or may not need an adapter to install it. If you want to connect it to the stock -4 AN schrader fitting on the rail then you'll need a -4 to 1/8" NPT adapter such as the one we carry.
Todd
Page generated in 0.12616 seconds with 13 queries
