| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
![]() Join Date: Nov 2003
Member Number: 5042
I am looking to buy the dual Aeroforce gauges, but am wondering what else would I need besides Inovate's LC-1 A/F kit to work along with gauges?
I guess it depends on what you need to see. These are available from the OBD2 port: 1. INTAKE AIR- Intake Air Temperature taken at the throttle body inlet 2. AMBIENT AIR TEMPERATURE – air temperature at the air filter 3. COOLANT TEMP- Engine Coolant Temperature 4. RPM- engine Revolutions Per Minute 5. CALCULATED AIR FLOW RATE- Mass Air Flow (lbs/min) calculated by the PCM 6. BAROMETRIC PRESSURE – ambient (outside) air pressure 7. MANIFOLD PSI- Manifold Air Pressure (psi) 8. THROTTLE POS PCT- Throttle Position percentage (0-100%) 9. THROTTLE VOLTS- Throttle Position sensor output (0-5 volts) 10. MILES PER HOUR- Miles Per Hour 11. KNOCK RETARD- Knock Retard (degrees) 12. KNOCK SENSOR RAW VOLTAGE – voltage output of knock sensor 13. WASTEGATE SOLENOID % DUTY CYCLE – programmed wastegate Duty cycle, 0-100% 14. SHORT TRIM FUEL TRIM- short term fuel trim 15. LONG TRIM FUEL TRIM – long term fuel trim 16. OXYGEN SENSOR - O2 bank 1 sensor in millivolts 17. FUEL LEVEL – amount of fuel in the tank in gallons. 18. EXHAUST GAS TEMP – calculated/determined by the PCM 19. TRANS TEMP- Transmission Temperature (auto transmission only) 20. RUN TIME MINS- engine run time since last engine start. Can be used as a trip timer. 21. BATTERY VOLTAGE- Alternator/battery output voltage 22. BATTERY TEMP - Battery Temperature 22. PULSE WIDTH- injector pulse width 23. FUEL TEMPERATURE 24. BASE SPARK TIMING – timing level commanded by the PCM before adjustments due to temperature, knock, etc. 25. SPARK ADJUST – adjustments made to base spark timing 26. IGNITION ADVANCE- final ignition timing advance after adjustments 27. ENGINE LOAD-calculated Engine Load (0-100%) 28. Miles Per Gallon- instantaneous fuel economy 29. Calculated net horsepower 30. TOTAL MISFIRES- Total misfires of all cylinders. 31. Analog 1 – analog input #1. 32. Analog 2 – analog input #2 33. Fuel status (open/closed loop) Plus you can control the cooling fans with it. We have fuel, oil, 3 bar MAP, fluid (oil) temp sensor kits that can be connected to the analog inputs. Todd |
#3 (permalink) |
![]() Join Date: Dec 2004
Member Number: 21617
Well in addition to the stated above items, i also want to measure AFR like Autometer and AEM's wide bands. I have checked the A/F kits coming summer 07, but I haven't seen a release date on them yet. That's why I asked what else other than Inovate's LC-1 would I need to make the LC-1 opperate properly with your gauges to read AFR. Thanks.
#4 (permalink) |
Member Number: 5042
To read A/F with the Innovate or Autometer you don't need anything besides one of these and our gauge. Both have an analog out wire that connects to one of our analog inputs.
Todd |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
