Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Aeroforce Technology
Old 02-12-2008, 06:02 PM   #1 (permalink)
srt4srsexy's Avatar
Member Number: 37107
Default aeroforce gauge and sct flash
will the aeroforce gauge work with the sct flash kit.
srt4srsexy is offline   Reply With Quote
Old 02-12-2008, 06:46 PM   #2 (permalink)
Member Number: 31650
yep, i'm program stage 2 in the stock pcm
and everything is good
the only time it's not working is when the gage is unhook and programing with my xcal
Not stock anymore
Old 02-28-2008, 06:52 PM   #3 (permalink)
NoisufnoC's Avatar
Member Number: 136
works great over here!
omgz!! i haz mods!!
NoisufnoC is online now   Reply With Quote
Old 03-20-2008, 06:38 AM   #4 (permalink)
05commemorative88's Avatar
Member Number: 52296
Trader Rating: (25)
yep no problems at, the sct really doesn't change how the ecu operates just some of the values that allow the ecu to operate with more fuel and boost are changed.
05commemorative88 is offline   Reply With Quote
Old 03-24-2008, 05:20 AM   #5 (permalink)
Member Number: 24279
Its quite interesting to compare certain parameters on the scangauge between stock & modified flashes .
For example , take a look at the relationship between throttle position & wastegate solinoid dutycycle on a stock map . Then load in the sct93 map . there is a big difference in how the wastegate reacts to throttle position , and you can see that in the data .
It just makes me want the Pro racer package that much more !
_____ _____
apexcrazy is offline   Reply With Quote
» Search Used Cars
Page generated in 0.18464 seconds with 11 queries
