Old 09-09-2008, 09:03 PM   #1 (permalink)
gotbst05's Avatar
Member Number: 37403
Trader Rating: (10)
Default aem uego & scangauge how to?
is there a "how to" out there that shows you how to hook up the uego and scangauge together and the settings that need to be input. i thought that i had seen one before, but now i can't seem to find it. thanks!
gotbst05 is offline   Reply With Quote
Old 09-09-2008, 09:11 PM   #2 (permalink)
quickshift's Avatar
Member Number: 55168
Trader Rating: (32)
bump. for how to
BEST ET: 12.68@110 stg 0, stock turbo, stock intercooler, pump gas, & no meth
MODS ADDED SINCE THIS RUN: AGP BB .50T with all supporting mods
quickshift is offline   Reply With Quote
Old 09-10-2008, 06:53 AM   #3 (permalink)
MoparbeastSRT4's Avatar
Member Number: 32388
I posted this a while back on a thread here somewhere, hope it helps.
I hooked up my AEM UEGO to the SRT-4 Interceptor gauge today.
This was very easy, the output from the wideband is the white 0.5 V wire and the Interceptor has a green and a white one, the white one is Input 1 so this is the one I used (could use either one ), then this is what Todd told me to do.
Turn the gauge on and scroll through the menu and select the appropriate analog input which I used Input 1 . You'll go to a new screen which will allow you to enter the conversion (slope = 002.0, intercept = 010.0) for this AEM unit (voltage * 2 +10 = A/F ratio) and it worked perfectly. I can't wait to record my A/F Ratios, I'll let u know how everything worked out later on .
http://www.cardomain.com/ride/2098862/1
Power Mods
Mopar Stage 1|Mopar CatBack|NWs V5 DP|AGP WG+PTP's spring|Greddy TT|Profec B Spec II|MPx FMIC|AEM SRI|AEM UEGO|Scan Gauge|ED Pipes+HKS BOV|MSD SPW+NGK@.32|MM Inserts|WeaponR CC|PTP's 75 FPR Mod, MAPTIP Clamp, Cooling Kit, Check Valve|
Quote: Originally Posted by yeah
My srt is possessed with deamons.
MoparbeastSRT4 is offline   Reply With Quote
Old 09-11-2008, 11:25 AM   #4 (permalink)
gotbst05's Avatar
Trader Rating: (10)
thanks for the help there boss! hope i can figure out how to datalog with a laptop
Old 09-11-2008, 01:39 PM   #5 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (33)
Also, the directions of how to set up the analog inputs in the Interceptor user manual uses the AEM Uego as an example. It tells you everything you need to know:
http://www.aeroforcetech.com/files/I...AL_rev_2_5.pdf
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 09-21-2008, 07:55 PM   #6 (permalink)
gotbst05's Avatar
Trader Rating: (10)
so it is possible to datalog with a laptop? i really wanna be able to record both my a/f and rpm ranges so i can tune with my safc2. i still haven't read or found anywhere that says this is possible.
Old 09-23-2008, 02:44 PM   #7 (permalink)
Member Number: 5042
Trader Rating: (33)
the gauge records to its own internal memory, there is no output for a laptop connection.
Old 09-27-2008, 11:49 PM   #8 (permalink)
gotbst05's Avatar
Trader Rating: (10)
well... wished it did. are you guys doing any research on how to maybe in the future have that option available?
Page generated in 0.14342 seconds with 13 queries
