Old 03-01-2007, 12:29 PM   #61 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (13)
S3 car running stock turbo for a couple weeks while my S3 gets a massage. Lol
I have Zeitronix wideband as well as Aeroforce & the O2 reading I'm seeing is 924v at 10.4 at WOT. Seems different than what some of you guys have seen. It jumps around a lot so it's not a good tool compared to real wideband.
On TPS at idle I'm at 17% & WOT is 79/80.
On stock turbo, Cruising on the freeway at 80 I'm right at 1500 degrees. At wot it is going to 1650. I don't have my EGT probe setup for the stock manifold, only my S3 so no comparison yet.
Is ambient air out side temp? Or the difference between out side & intake temps? My ambient temps are lower than my intake temps. Not sure what they are supposed to be, but ambient is lower than outside air temp. maybe mine is off somehow.
Not seeing any knock value, but I am seeing 0-2 knock voltage. At what voltage does it become a knock reading?
Ignition advance has been from the teems to 60 at times. I have not tried advance at WOT. maybe at lunch.
Boost has been between -18 to 20Psi. Exact match to my Zeitronix digital guage. Glad to see that.
11.9@117 so far.
Wiseman - Just cuz someone else has a fast car with the same parts as you, doesn't mean your car is fast.
Work harder, millions of people on welfare are depending on you.
srt4geezer is offline   Reply With Quote
Old 03-06-2007, 04:15 PM   #62 (permalink)
forcefedjunkie's Avatar
Member Number: 5042
Trader Rating: (33)
The ambient air temp sensor is not a precision measurement. The output is not linear either so converting it to temperature is tricky. It will read a few degrees low when it's cold outside (below 40 deg F). The sensor is located just downstream of the air filter. Yours reads the same as everyones.
You should not use the stock O2 sensors to determine A/F ratio. If the Zeitronix has a linear 0-5v output you can run that the Interceptor and read A/F there as well as log it. This is what I do with a AEM unit.
Todd
12.80 @ 115
Aeroforce Technology Inc.
Old 11-27-2007, 09:56 AM   #63 (permalink)
Adrian_RT's Avatar
Member Number: 28781
nice post....
Adrian_RT is offline   Reply With Quote
Old 11-27-2007, 12:50 PM   #64 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (13)
Anyone know a way to correct the throttle percentage so it reads zero & 100% rather than 17 - 70%?
Old 11-27-2007, 02:47 PM   #65 (permalink)
Member Number: 5042
Trader Rating: (33)
That's how the output is scaled by the PCM. There's really nothing you can do about it.
Todd
Old 01-01-2008, 12:32 AM   #66 (permalink)
Member Number: 31650
maybe some paramater should be added in the first tread...if i remember correctly this tread is alive since the original version...
less info...i prefer my upgraded pro version
Not stock anymore
moreause is online now   Reply With Quote
Old 12-07-2008, 06:09 PM   #67 (permalink)
Member Number: 31038
Trader Rating: (50)
Could this thread please be updated with all the "Pro" v-2.5 parameters and what they should read?
thanks.
I just got mine and I love it! Most of the stuff I have no clue what it should be.
raul-01 is online now   Reply With Quote
Old 01-07-2009, 03:30 PM   #68 (permalink)
Trader Rating: (50)
thanks.
Anybody?
Old 01-07-2009, 08:32 PM   #69 (permalink)
Member Number: 5042
Trader Rating: (33)
If you do a search in this forum you should be able to find an answer for most of the parameters. If you have specific questions on any that you cannot find posted here I can try to help.
Todd
Old 02-18-2009, 09:06 AM   #70 (permalink)
Member Number: 51751
So is a positive Long Term Fuel Trim adding fuel and a negitive taking fuel?
dohc122acr is offline   Reply With Quote
Old 02-18-2009, 01:49 PM   #71 (permalink)
Member Number: 5042
Trader Rating: (33)
That is correct.
Todd
Page generated in 0.18721 seconds with 13 queries
