#1 (permalink) |
![]() ![]() Join Date: Sep 2004
Member Number: 17477
this thread will be about my BWS. have info, dyno #s, charts and time slips...
lets keep this one on topic please....
DCR spiced and Tuned by the Mad Scientist team
![]() Jay@N2MB and Nigel@BST (turbo666) Mole' (STOCK TURBO) 16g BWS setup #s 380hp+ and 444tq+ 11.7@122 1.71 60ft PM/email me for all your 16g/18g/20g BWS setup and DCR needs...... Darrell Cox Racing on facebook, 1-517-369-9636 10am-5pm est webstore... DCRSRT.com. email me at mole79@aol.com . |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
![]() 16g BWS vs 18g BWS DCR mod ![]() BWS DCR 3" mod housing ![]() Mole' 16g BWS vs Mole' BWS with DCR 3" Bell-mouth/Anti surge mod ![]() Mole' BWS discharge vs stock ![]() Mole' BWS3 47lbs ![]() Mole' BWS3 47lbs s3 race ported mani ![]() ![]() ![]() Custom BWS wheel I had made. GTX 10blade design ![]() ![]() Mole' BWS3 20g vs Mole' BWS 16g ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() custom 18g billet BWS wheel ![]() ![]() and a few turbos from work ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
![]() Jay@N2MB and Nigel@BST (turbo666) Mole' (STOCK TURBO) 16g BWS setup #s 380hp+ and 444tq+ 11.7@122 1.71 60ft PM/email me for all your 16g/18g/20g BWS setup and DCR needs...... Darrell Cox Racing on facebook, 1-517-369-9636 10am-5pm est webstore... DCRSRT.com. email me at mole79@aol.com . Last edited by mole'; 05-15-2013 at 11:33 PM. |
#3 (permalink) |
TURBO BRAKE-IN AND PRIMING INFO.
Before you startup your car after installing one of my BWS. You need to first prime the turbo with oil. Unplug the coil pack, pull the fuel pump relay and spark plugs. Crank once or twice for 15 seconds and then listen/ inspect for leaks. After that crank continuous until low oil light goes out. Could be 2 minutes. The turbo will then be primed with oil. Now you can plug the coil pack, fuel pump relay/plugs back in. Double check everything and then start up and let the car idle for 5 minutes and listen/ inspect for leaks. Shut the car off and check for leaks. If all is good, its time to go take the car for a spin. Start off with 0 ZERO boost for the first 50 miles. Check or leaks/inspect after the 50 miles. After that you can do lite boost (5-10psi) for 50 more miles. Then after that you can go into your normal boost.
![]() Jay@N2MB and Nigel@BST (turbo666) Mole' (STOCK TURBO) 16g BWS setup #s 380hp+ and 444tq+ 11.7@122 1.71 60ft PM/email me for all your 16g/18g/20g BWS setup and DCR needs...... Darrell Cox Racing on facebook, 1-517-369-9636 10am-5pm est webstore... DCRSRT.com. email me at mole79@aol.com . Last edited by mole'; 04-05-2012 at 12:15 PM. |
#4 (permalink) |
PRICES!!!
Mole' 16g BWS $499 plus a good core DCR 3" Bellmouth/Anti-surge mod $350 i offer a discount is bought together. you can order via me or with DCR. we also offer exhaust manifolds to go with your BWS. from a basic ported mani, race ported/elbow mod mani to the DCR Mighty Mouse manifold.
![]() Jay@N2MB and Nigel@BST (turbo666) Mole' (STOCK TURBO) 16g BWS setup #s 380hp+ and 444tq+ 11.7@122 1.71 60ft PM/email me for all your 16g/18g/20g BWS setup and DCR needs...... Darrell Cox Racing on facebook, 1-517-369-9636 10am-5pm est webstore... DCRSRT.com. email me at mole79@aol.com . Last edited by mole'; 04-05-2012 at 12:52 PM. |
#5 (permalink) |
SRT of the Month ![]() Join Date: Aug 2005
Member Number: 32888
tylers boost map, he is using PCM boost with ~95% wgdc with fm wg
![]() my boost map, I'm using n2mb box, set at 24 psi in 3rd. This is the latest log I've done.(as my car sits as of 4/5/12.) ![]() I did track my car on the bws. Ill post a log of the boost and timing. Horrible. I let the car get over 210 degrees. I was talking to my passenger and wasn't paying attention. 12.4 @113 time slip is in video info. ![]() haha i said holy shit and was flying.. haha, surprised me.. i dont know might be slow.... still only at 23-24 psi...
#6 (permalink) |
^^ if you would like a boost and timing chart done like above I can just send me a pm. I just need a copy of your log. I will pm you my email address. Also give me a few days to return it. Thanks.
If you have a question and u think it will get deleted Pm me!!!! FYI I can not delete post.
#7 (permalink) |
Retired Member
![]() Join Date: Apr 2004
Member Number: 9649
Mole's Cars Peak Hp and Tq in Correction: SAE & Smoothing: 5
![]() Mole's Cars Peak Hp and Tq in Correction: STD & Smoothing: 0. Strictly posted for comparison sake against others that do not post the industry standard "Smoothing/5" corrections. ![]() Mole's cars final Dyno pull for the day, may not be the "peak" numbers, but it shows a nice fat power band. ![]() Another look at the above pull showing the turbo held nearly 360 HP to 5800 RPM's (an 11 HP drop at 5800 RPM's from it's "peak" power) ![]() Mole's cars boost levels. Please do not read to much into this. The Dyno used a GM 3 bar sensor hooked up through a long like 8 food sample line. Because of this there was lots of osilation and pulses in the sample line. Jay from N2MB can verify from the DSP logs that the boost holds rock soild and dosen't osilate as much as this graph reflects.
#10 (permalink) |
never put it on a scale. so im not sure.
#12 (permalink) |
mole u should add how much it is, whats the turn around time, etc....
post #4 we picked up extra cores so were gonna try and keep some instock on the shevles ready to go....
#13 (permalink) |
BS has started already. i WILL delete post that are not called for......
#14 (permalink) |
Member Number: 17238
o didnt see that lol, if u buy them wit out a core how much, and after reciving turbo can i still send my core and get refunded, i just dont want to have my car down for too long as my daily is being used by my dad right now
#15 (permalink) |
i forgot to add that part. core charge is $200 on the turbo. you have 2 weeks to return a good core ( rebuildable, no bent shaft, good ext wheel) and then your core charge will be refunded. same goes for an exhaust manifold. good core (not all cracked up, nothing broken off of it)
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
