Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Darrell Cox Racing
Old 02-18-2007, 05:39 PM   #16 (permalink)
Member Number: 31404
Honestly, it doesn't really matter. More of a preferance.
When i was still modding V8s and installing supercharer kits on mustangs and camaros most of the supercharger companies told us in the directions to vent the breathers to the atmosphere and to simply run down the side of the engine bay.
As long as you don't have rings that are very worn, you won't be dumping much oil at all.
The Consolidator is offline   Reply With Quote
Old 02-19-2007, 06:58 PM   #17 (permalink)
Mid-Atlantic Moderator
snkmug's Avatar
Member Number: 24604
Trader Rating: (46)
Quote: Originally Posted by XXxx_Totmacher_xxXX
I've seen a few cars with a breather that had major ring blow by on the Dyno and yeah it's not pretty. lol It's like the Mobil 1 version of old faithfull.
like mine
snkmug is offline   Reply With Quote
Old 02-19-2007, 10:41 PM   #18 (permalink)
XXxx_Totmacher_xxXX's Avatar
Member Number: 9649
Trader Rating: (38)
I honestly meant valve seal, not ring, but yeah Shawn your car came to mind and most recently Chris' car.
Honestly I think this is a dumb topic and don't know why it keeps surfacing. just keep the pcv valve routed to the TB to maintain a vac source on the case, and put a breather on the driver side. Only thing above and beyond that is to put a check valve in between the TB and PCV valve. I don't get what is so hard to understand and accept about that.
_
Neon SRT-4
11.431 @ 123.61_____417 Hp / 450 Tq
Caliber SRT-4
12.782 @ 111.09_____407 Hp / 460 Tq
Tuned By Totmacher
_
XXxx_Totmacher_xxXX is offline   Reply With Quote
Old 02-23-2007, 02:13 PM   #19 (permalink)
Cruiserdude's Avatar
Member Number: 2849
Still waiting to hear what Darrell has to say, but I've been running a hose to a catch can running to a filter ziptied to the driver's side upper rad. mount. Works fine, no problems here.
Praying for HemiDakota, hang in there!
MODS:Stage 2 w/ toys, BDJ's 3" side exit exhaust, Maxxfab 3" O2 housing, PTP WGA (19-16 until I get an FMIC), Psi-fi CAI, Mopar sway bars, Psi-fi LCA's, Prothane MM inserts, MPx MM bolts, Mopar BOV, $20 catch can, Mopar STS w/ Boogers, T-Bolts, PTP checkvalve and heatshield
Wish List: MSD wires, FMIC, DCR oil mod, larger TB, w/i, fix my boost leaks and lean the car out a bit!
Cruiserdude is offline   Reply With Quote
Old 02-23-2007, 02:21 PM   #20 (permalink)
Ant @ Psi-Fi's Avatar
Member Number: 5230
Put a catch can between the valvecover and intake. The vacuum make for good ring seal.
Chess can bite my Psi-Fi Junk Christian's car will blow the doors off anything you have.
Ant @ Psi-Fi is offline   Reply With Quote
Old 02-23-2007, 05:17 PM   #21 (permalink)
darrell cox's Avatar
Member Number: 35031
Trader Rating: (161)
Its best to run the PCV thru a check valve to insure it from leaking while under boost. Next the engine really benefits from the added vacuum under boost if the drivers side of the valve cover is connected back to the air intake. There is alot of vacuum there while under boost. To insure no oil gets consumed from the air intake you install a recovery tank between the two. This way when the car is at idle and under no boost the PCV, hence the name (Positive Crankcase Ventilation) keeps vacuum applied to the engine. When the engine is under boost the air intake pulls a vacuum on the crankcase. Bottom line vacuum all of the time. The rings conform to the cylinders better with vacuum. Also ring flutter is minimal with vacuum keeping oil from being pushed by the rings and up onto the top of the pistons and combustion chambers. Out of all of the engines we have disassembled over the years you see it every time (the ones that are not connected to the air intake) also remember that engine oil added into the combustion process greatly reduces the fuels octane. This can causes unwanted detonation and spark knock. The crank seals, valve seals, and cam seals are designed around this vacuum. Also this greatly reduces windage in the crank case further adding proper oil control and some added performance.
Thanks
Darrell Cox Racing 276-956-2082
PayPal Addy; darrell@dcrsrt.com
Email; darrell @dcrsrt.com
Website DCRSRT.COM
The leaders in SRT4 Performance. Engine & Cylinder Head Specialists
In House Dynojet Dyno! Full In House Machine Shop! Custom Fabrication!
darrell cox is online now   Reply With Quote
Old 02-23-2007, 05:38 PM   #22 (permalink)
Breakin Newz's Avatar
Member Number: 10584
Thanks
Nice.. So there you go guys... You've gotten the answer from the man!
Breakin Newz is offline   Reply With Quote
Old 03-02-2007, 09:31 PM   #23 (permalink)
Big D's Blue 04's Avatar
Member Number: 32123
so glad I went with my gut on leaving that hooked up to the stock config. just added the check valve and catch tank.
813-892-7215 help with installs, mods, or sound SRT-4 advise
Big D's Blue 04 is offline   Reply With Quote
Old 03-04-2007, 06:01 PM   #24 (permalink)
Member Number: 24782
S**T Now I need to make a list of all the littlethings I need to do to the car to get it just right... I guess add this to it.
04 GT 5-speed
S1, K&N drop-in, air box mod,05 mani, TTAB & UCP, Magnacor wires & NGK plugs .035, Mopar dual exhaust
Eibach springs, Mopar Sways, strut bar
PTeazer bumperette, grille, Cowl Induction hood & rollpan, Wheel Vintiques Ralleye Billet Rims
01 painted heated mirrors, painted trim, debadged
Maxxfab O2 & DP pipes, AGP WGA, PPQ, soon to be adding Josh's stuff!!!
GR8FLPT is offline   Reply With Quote
Old 03-05-2007, 05:42 AM   #25 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
All,
I re-did mine per Darrell's instruction, I'll have a pic later.
Marion
Powered by Mopar Stage 1/3 Hybrid.
Cincinnati's next SRT's in the 11's
mario03srt is offline   Reply With Quote
Old 03-06-2007, 06:03 PM   #26 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
I added a barb to my intake and put in a catch can between the breather. So now I have constant vacuum to the valve cover. And no oil to the turbo. I kept my checkvalve/catch can setup on the pcv side as before.
So.....................comments?
Marion
Old 03-06-2007, 06:07 PM   #27 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (29)
looks good
JnR Performance=envied by many in norcal
Sponsored by DCR
for sale:
mopar short shifter 80 shipped obo
reed32 is offline   Reply With Quote
Old 03-06-2007, 09:08 PM   #28 (permalink)
Marion
Old 03-07-2007, 05:18 AM   #29 (permalink)
Ghowie's Avatar
Member Number: 33090
Trader Rating: (55)
Now lets say your intake has zero nipples to connect anything,what do you do then? Would running a t to the pcv line after the check valve work better than just having a filter on the valve cover?
Originally Posted by dansrt4
For a shop thats so behind maybe you should catch up on orders before you catch up to me.
Ghowie is offline   Reply With Quote
Old 03-07-2007, 05:30 AM   #30 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Ghowie,
My homebrew intake did not have a nipple on it. I just drilled a hole and threaded in the barb/nipple with a tad of silicone sealant on the barb where it meets the intake. The barbs can be found at any Home Depot etc. actually in the same area where you pick up the catch can in the air compressor accessories section.
Marion
» Search Used Cars
