Just throwing this out there, why would someone running the blue plate have to route the lines differently than someone who is only running the stock surge valve? The stock surge valve still works the same way when it comes to boost but only difference is that the blue plate vents to the atmosphere instead of re-circulating it.
I know this thread was started more than a year ago but I think someone brought this up already but the question was not addressed.
Can someone please answer this question cause I would like to know as well since I have the agp plate installed, and why do I need a fuel pressure regulator to run that setup?
You shouldn't need to run a fuel pressure regulator. I'm not and have a bop with a bov.
I think that it is shown this way incase you do have one you'll know how to tie it in.
Now does this vac setup work with stg3, cause when I did it I was only boosting 10psi do I need an aftermarket wga like agp's stg3 wga or is stock stg3 wga just fine?
Would I just run that line to my fuel rail instead....... and leave the rest the same?
Thanks,
Troy
Ook So I am stage 0 but I have BOV and agp wga and BOP. With the picture shown above, the blue line is not hooked up, and their are no vac lines hooked up to the solenoids. Is that how it goes? Also like I read from the OP you dont need to cap the solenoids? Lastly, with the blue line, since it was hooked up to the turbo and the solenoids, do I have to cap both or what?I just started to read this thread because I cannot boost more than 15psi, this thread made things a little bit more clearer on how I should run my lines. I just need a little bit more info.Also what the guy ^^ said, you don't need to hook up the line with the fuel reg if you don't have one, correct?
Also, do I need to run a bleeder or bleed from the turbo (green line) to the wga? Can I have a picture of the bleed(er) and the vaccum cap and where can I get these.
Thanks, Davey
LuLZ
_Cali's Most Wanted_
Quote: Originally Posted by Wizardsrt-4
She might be conservative but that's not a bad thing...
Could be a woman in the streets and a freak in the sheets!
Thanks Aaron. Car is running better than ever, thanks to using this set-up (using a AGP WGA) :
RUgoinUp 2 Heaven? Ever lie, steal, dishonor your parents, commit adultery, use God's name in vain? Those are only 5 of the 10 Commandments. Breaking one condemns you to Hell. Claiming to be a good person won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit you're guilty and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
no you have to still have the wiring to the solenoids hooked up but do not have to have any of the vacuum lines hooked into them.
You got it
www.Realtuned.com Each car built/tuned/track prepped in house
{11.62@128 Realtune Caliber}{11.85@119 Whoosh@Realtune Caliber} Home of the Worlds Quickest/Fastest CSRT-4, Manual NSRT4, and Stock turbo SRT4
