I have noticed their is like 60 replies and 52 of them are differnt questions I like the one about EBC should we re-do all vacuum lines instead of tapping from small hard vaccum line to a rubber line would that help jest re do them all?
one thing that i did notice that my car runs extremely rich, i have a safcII that i will be installing so that should take care of it, also I am running 19 psi of boost. i have noticed that when i mash the gas at like 3200 rpms in 3rd gear, it sounds like my hks ssq bov is opening up untill like 3600 rpms and then its shut. anyone know of anything that i might be able to do to solve this issue???
Ok everyone. I am STILL getting questions on Vac line setups after all these years. So here is some of my awesome art work to hopefully put an end to it.
Here is the stock setup:
Here is how I want you to do it. If you are using an MBC, just splice it in between the green line. If you have a big turbo, Everything is the same but you want the ''green'' line to go to the bottom port of the external WGA.
Here is how you do it if you have a Bov and are not using the surge valve. Or if you have a big turbo you need to do it this way also.
This is for the people using my external WGA stock turbo manifold.
No the solenoids do NOT have to be plugged. I also pictured where I want you to hook your boost source for your fuel return line. If you do not have a port on your UPP[agp UPP] than you will run it to the throttle body and put a one way check valve in line with it.
This should be the end all for you guys. Please do not make it harder than it is with...''hey I did this, will this work?''. This is how it should be done IMO.
Just follow the diagram and you will be golden.
HOLA AARON, DISCULPA QUE TE MOLESTE, pero te quiero hacer una pregunta sobre el dibujo numero 4 el ultimo que pusiste en este post, las lineas de VAC la ROJA Y LA BLANCA DEL TIP, las cancelo??, Ya no las tengo que usar?? las puedo quitar del solenoide rojo?
www.Realtuned.com Each car built/tuned/track prepped in house
{11.62@128 Realtune Caliber}{11.85@119 Whoosh@Realtune Caliber} Home of the Worlds Quickest/Fastest CSRT-4, Manual NSRT4, and Stock turbo SRT4
Sorry, I havent a clue as to what your saying. I only speak Engrish
