Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > RealTune Performance
Old 04-21-2007, 12:40 AM   #46 (permalink)
XXxx_Totmacher_xxXX's Avatar
Member Number: 9649
Trader Rating: (43)
Quote: Originally Posted by srt4_roller
Quote: Originally Posted by Canuck_2k
hey..
i took out the red and white line. I need to know what to do w/ the solenoid? the plug had a lil filter in it.. do I cap all 3 holes or just the one for the filter?
you can leave the ones with the little filters on. but the rest cap off and use zip ties. and crank them ties down hard!
wrong, you do not need to do anything at all.
Neon SRT-4 (Mine)
11.431 @ 123.61___600 Hp/500 Tq
Crossfire SRT-6 (Wife)
??.?? @ ???.??___331 Hp/310 Tq
Neon SRT-4 (Red Sled)
9.316 @ 156.50___9?? Hp/6?? Tq
Caliber SRT-4 (Red Shed)
12.079 @ 114.92___568 Hp/504 Tq
XXxx_Totmacher_xxXX is offline   Reply With Quote
Old 04-21-2007, 12:50 AM   #47 (permalink)
srt4_roller's Avatar
Member Number: 38992
hey..
i was told to do that. (I stand corrected)I have yet to run my car, just installed the 50 trim and i asked the same question. So i just uncap them and just let them and leave them to the atmosphere? Can you help on this then? Im an 05 with stage 2 also and should i keep the white vac and red vac hooked then?
srt4_roller is offline   Reply With Quote
Old 04-21-2007, 09:34 PM   #48 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (65)
hey..
pull em all out and leave em exposed? meaning no filter? nothing?
http://www.SRTCanada.com <----- alternate site for canadians.
DiabloSport Trinity Beta Tester
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 04-23-2007, 01:21 AM   #49 (permalink)
Dman_23's Avatar
Member Number: 31915
Trader Rating: (25)
hey arron, in the picture with the rice plate set-up. The black line is Tee'ed with the blue line and a line runs to the intake. Do i untee them and just hook them straight up seperatly or leave them how they are?
Project "Stockness" is on hold...
Dman_23 is offline   Reply With Quote
Old 04-23-2007, 11:59 AM   #50 (permalink)
Member Number: 9649
Trader Rating: (43)
that is not a T, the lines are just crossing over eachother.
Old 04-23-2007, 12:06 PM   #51 (permalink)
Member Number: 9649
Trader Rating: (43)
Not stepping on Aaron's toes, but the original poster of that pictures had a few lines mixed up, the brake booster (with boost gauge and HVAC) is feed of the bottom of the Intake manifold, not the TB spacer. And the Evap/emissions line is hooked into the TB spacer/Turbo outlet nipple and stock air box elbow.
he had those 2 flipped.
In the bottom right of your opened hood is a pretty decent drawing of the stock vac line setup. Lots of people don't realize this.
Old 04-29-2007, 07:33 AM   #52 (permalink)
Sick SRT4's Avatar
Member Number: 49174
I LOVE the paintshop artwork, lol.
People Call Me "Junior"
Sick SRT4 is offline   Reply With Quote
Old 05-05-2007, 09:35 AM   #53 (permalink)
FtBraggSrt4's Avatar
Member Number: 8621
So Im taking off the vacuum line that goes from the brakebooster to the intake mani and hooking it uo to the TB? I left the brake booster connected to the mani and hooked up the pink line to the lines coming off the TB.
1200AM 10 November----> GameStop
1215AM 10 November----> Online with Modern Warfare
FtBraggSrt4 is offline   Reply With Quote
Old 05-09-2007, 03:09 PM   #54 (permalink)
Member Number: 9649
Trader Rating: (43)
see my reply #51
Old 05-09-2007, 05:23 PM   #55 (permalink)
Member Number: 8621
yea i figured it out. thnx anyways
Old 05-15-2007, 10:09 PM   #56 (permalink)
pepper323's Avatar
Member Number: 41533
Default help! check engine light
just installed the agp wga and followed the directions. i have installed: Mopar BOV, Stage 1 PCM, CAI. I ran the greenline to the wga with the bleed fitting. the #2 solonoid has no caps where the the black and green lines use to be. why is the check engine light on. can someone please help me
pepper323 is offline   Reply With Quote
Old 05-16-2007, 12:40 AM   #57 (permalink)
Member Number: 52963
I am running a SRT turbo on a DOHC 1g, and ofc I don't have the solenoids.
The MBC and WGA are working beautifully by running the "green" line from turbo to mbc to wga.
Only problem I have is the stock "boost leak" (bov). Is there a way to make it stop leaking all the time? I have it connected to the intake manifold after the throttle plate and the damn thing leaks unless I am at WOT. Anything under WOT and it leaks horrible, causing the turbo to spin to much, causing more unwanted heat in my intake charge.
Any ideas besides new BOV?
I was thinking crush it like the 1g DSM guys used to do. Think this would help?
TurboLover! is offline   Reply With Quote
Old 05-16-2007, 12:24 PM   #58 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (44)
Aaron,
I removed ALL of my lines on the solonoid, capped the turbo, and capped the little green thing in the middle of the lines.
I was tuned to 12.2 at the punch 3rd gear 3000 rpms. The next day when I drove the car, it was at 13.3???? what the hel happened. I had to turn back my mapclamp a bunch, maybe 2.5 full turns to get back to 12.0.
Some things are pathetic!
Performance Mods: AGP S3D 48lb - Returnline - Mopar Stage 2 w/o Toys - DW 650cc - TurboXS HPMBC - Maddog STS - MaxxFab 3" DP w/o Cat Magnaflow Muffler - AIS Intercooler - ED LPP - ED UPP w/ HKS BOV - Injen Intake - NGK V-Powers @ .032 - FBM Ported Intake Mani/Spacer - DCR 55mm Throttle Body - DCR Oil Mod - Devils Own MethInjection, M5 - DTEC - AEM UEGO
385HP and 385TQ
Gmanigio is offline   Reply With Quote
Old 05-16-2007, 12:27 PM   #59 (permalink)
SRTGallardo's Avatar
Member Number: 39792
Quote: Originally Posted by JCsrt04
so that third pic down will work for a s2 stock turbo with HKS BOV and Kinetic WGA without any problems or chekc engine lights?
will I NEED to run a return line (haven't installed it yet) or can I get away with not running the return line for now?
Bump. Do I need a return line or clamp?
Oh and Check valve's needed anywhere?
Any Car > WRX's > Ford's
Basic Stage 1
SRTGallardo is offline   Reply With Quote
Old 06-04-2007, 05:57 PM   #60 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (44)
I have everyline off of the solonoids. Can I unplug the "1" "2" and "3" electrical connection and set them aside somewhere?? Or do they have to be plugged in?
THanks
GC
Page generated in 0.16399 seconds with 13 queries
