Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > RealTune Performance
Old 03-17-2007, 04:07 PM   #31 (permalink)
Member Number: 37321
i tried to mess with the vaccum line when i first had the car and it wouldnt go over 3 lbs of boost after i tried to run lines differently. so i just leave the solenoids completly open still plugged in and dont plug them and run my lines like in aaronn diagrahm and im done?
stinky2004 is offline   Reply With Quote
Old 03-17-2007, 05:22 PM   #32 (permalink)
manicou_1's Avatar
Member Number: 42410
Trader Rating: (20)
yes sir
manicou_1 is offline   Reply With Quote
Old 03-17-2007, 09:25 PM   #33 (permalink)
ill trust u guys and try it thanks
Old 03-19-2007, 10:56 PM   #34 (permalink)
hardcore's Avatar
Member Number: 30646
question about the differences between the diagrams with and without the rice plate and stock bypass valve.
I understand keeping the solenoid in when using the rice plate, because it dumps to the atmosphere. Why wouldn't you leave the stock solenoid in control of the bypass valve without the rice plate? It will still vent during the same conditions that the rice plate will, you just wont be able to hear it because it vents right back into the manifold before the compressor.
----The Old----
Stock Turbo+fuel/tuning+boltons.13.37@110(2.2 60')
---The New----
GT3071R
12.9 @ 119.6 (2.3 60' on Ventus RS2's) with diablosport
Dynoed 372whp
hardcore is offline   Reply With Quote
Old 03-19-2007, 11:10 PM   #35 (permalink)
Member Number: 47371
what does the rice plate setup gain? I've had it on for awhile but I don't think we changed the lines around. Will go look at it tomorrow. Did i miss where the how to is and can it be easily swapped back and forth say if I need dealer service?
MYTsmylee is offline   Reply With Quote
Old 03-20-2007, 11:56 AM   #36 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (65)
i see you guys took the red and white line out of the stock lines set-up.
I've asked ya that when I was at your shop and you felt it isnt needed to be removed...
so.. leave it or remove it? even though Im going to run water/meth injection soon?
http://www.SRTCanada.com <----- alternate site for canadians.
DiabloSport Trinity Beta Tester
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 03-20-2007, 07:43 PM   #37 (permalink)
Member Number: 12231
Trader Rating: (35)
so no a pic for use guys that have ems with big turbo. And want the ems to control boost?
SOLD CAR dsm project underway..
v8killa04 is offline   Reply With Quote
Old 03-26-2007, 07:06 PM   #38 (permalink)
Trader Rating: (35)
bump^^^
Old 04-04-2007, 03:41 PM   #39 (permalink)
FtBraggSrt4's Avatar
Member Number: 8621
What was used to cap the nipple on the turbo(where the blue line used to go).
1200AM 10 November----> GameStop
1215AM 10 November----> Online with Modern Warfare
FtBraggSrt4 is offline   Reply With Quote
Old 04-04-2007, 05:14 PM   #40 (permalink)
manicou_1's Avatar
Trader Rating: (20)
just a vacuum cap.
Old 04-16-2007, 04:05 PM   #41 (permalink)
scrivenerc's Avatar
Member Number: 32817
Trader Rating: (24)
What if Im running a ebc? I have the profec B, I have a wite vac line, a pink line, and a blue I think. Do I need any of these or can I just cap all of them. Mods are in my sig.
scrivenerc is offline   Reply With Quote
Old 04-17-2007, 11:19 AM   #42 (permalink)
srt4_roller's Avatar
Member Number: 38992
ok just making sure that i read this right...
I have the agp 50 trim w/stage 2. so i dont need any vacuum lines it says in the install directions. so im left with the tip and the red line just pull those off too? and leave the soleinoids plugged in but dont capp them off at the vacuum spots right? just making sure before i fire her up!
srt4_roller is offline   Reply With Quote
Old 04-19-2007, 12:51 PM   #43 (permalink)
Member Number: 18368
Trader Rating: (32)
so that third pic down will work for a s2 stock turbo with HKS BOV and Kinetic WGA without any problems or chekc engine lights?
will I NEED to run a return line (haven't installed it yet) or can I get away with not running the return line for now?
JCsrt04 is offline   Reply With Quote
Old 04-20-2007, 08:13 PM   #44 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (65)
hey..
i took out the red and white line. I need to know what to do w/ the solenoid? the plug had a lil filter in it.. do I cap all 3 holes or just the one for the filter?
Old 04-20-2007, 10:51 PM   #45 (permalink)
Quote: Originally Posted by Canuck_2k
hey..
you can leave the ones with the little filters on. but the rest cap off and use zip ties. and crank them ties down hard!
Page generated in 0.25373 seconds with 13 queries
