Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > RealTune Performance
Old 06-25-2006, 11:08 AM   #16 (permalink)
Stryker6040's Avatar
Member Number: 13831
Trader Rating: (13)
Quote: Originally Posted by pettyracing
Quote: Originally Posted by CRZYCUBAN2
Im ready to buy one with it already fixed from you or from Kinetic.
If your thinking about buying the Kinetic 60mm TB you better buy it now.Kinetic is no longer making anymore TB except for whats in stock.Just found out today.Got mine.
is this true aaron?
Stryker6040 is offline   Reply With Quote
Old 06-25-2006, 11:17 AM   #17 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (431)
is this true aaron?
Well I dont know this as a fact but its more than likely. They worked with the company that made them and gave them strict guidelines to follow, and as you can see with the new seal.. they didnt follow them. So I would be suprised if they made another batch. They are a very nice piece indeed, but Kinetic has a high standard and doesnt want to add a piece to something that should have it built it. I will find out how many are left and what the deal is tomorow
www.Realtuned.com
Each car built/tuned/track prepped in house
{11.62@128 Realtune Caliber}{11.85@119 Whoosh@Realtune Caliber}
Home of the Worlds Quickest/Fastest CSRT-4, Manual NSRT4, and Stock turbo SRT4
Old 06-26-2006, 01:13 AM   #18 (permalink)
TurboSrt-Four's Avatar
Member Number: 12698
Trader Rating: (18)
Where can we get that washer and federal mogul seal?
Does this work on the Lorenzo 60mm TB?
Is the Idle Screw Adjustment needed on the Lorenzo?
2004 Dodge SRT-4 Flame Red
TurboSrt-Four is offline   Reply With Quote
Old 06-27-2006, 05:09 PM   #19 (permalink)
Member Number: 37864
Trader Rating: (10)
Bump I would like to know where to get the seal and wasker too Aaron or SRT4FUN80!
JusANeon is offline   Reply With Quote
Old 06-27-2006, 05:17 PM   #20 (permalink)
Member Number: 623
Dont know about the lorenzo.
Good luck finding the seal. They are an industrial seal and very hard to find. Im still waiting for the past 2 week now. Kinetic has enough for the rest of their TBs and thats it
Old 06-27-2006, 05:17 PM   #21 (permalink)
Member Number: 623
Not sure right now. Big pain in the arse to get ahold of.
Old 06-27-2006, 05:47 PM   #22 (permalink)
srt4fun80's Avatar
Member Number: 34189
Trader Rating: (102)
i have no idea. this was aaron's find not mine. i just contributed a write up on the performance of the throttle body. Which I still feel is the best available IF indeed it still is. I haven't heard anything from Kinetic stating otherwise. Mine also is not leaking that I know of. The first boost leak test showed no leaks. Not sure if it has started since then but boost is the same and still holding 15/16 to redline.
srt4fun80 is offline   Reply With Quote
Old 06-27-2006, 06:00 PM   #23 (permalink)
David40836's Avatar
Member Number: 37532
Where did that 3rd had come from???? Mine doesnt have any finger. Bet your a popular guy with the girls
J/K
Nice Nice fix. thank you for the work and look into. Sticky this pig!!!
David40836 is offline   Reply With Quote
Old 06-27-2006, 06:04 PM   #24 (permalink)
Member Number: 623
J/K
All the lovely ladies love Realtune
Old 06-27-2006, 06:22 PM   #25 (permalink)
David40836's Avatar
Hahaha if you help me you can have mine and my first born. this is off the topic but I posted a thread called BOV help that I would appreciate your help with bud.
Thanks for this write up regardless.
Old 08-26-2006, 03:29 AM   #26 (permalink)
Member Number: 11681
Trader Rating: (96)
HEYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY YYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY YYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY
now i got your attn. yes it works for the zapp. Now im finding leaks everywhere prolly cause the TB isent leaking as it used to. My aeromotive FPR was leaking at the vac/boost source nipple on the back so got that fixed then the adjuster threads on the top were. Im playing with that as i type that but this fits the ZAPP and works
2nd Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
3147 7.49/102 11.51/124 so far 28psi
3147 7.26/100 22psi pump full int
Old 08-26-2006, 12:46 PM   #27 (permalink)
Member Number: 623
Yes sir. Always wrap the vacuum nipple and aduster nut in teflon tape
Old 08-27-2006, 01:42 AM   #28 (permalink)
Trader Rating: (96)
Well since the TB was leaking even after the old zapp fix there was freakin 3 other leaks i ended up having to cut the zip ties off and use clamps because they were about to blow off and/or leaking like mad.
Its nice to see the zapp guys/girls finally having a cure for the pain we suffered lol.
Old 03-30-2007, 06:50 PM   #29 (permalink)
neonmarine's Avatar
Member Number: 21010
Trader Rating: (32)
So Zapp is Lorenzo? I need to fix the leaks!!!!! I'm only holding 14 at redline!!!
neonmarine is offline   Reply With Quote
Old 07-22-2007, 08:05 PM   #30 (permalink)
BTR
BTR's Avatar
Member Number: 11347
Trader Rating: (43)
ok where can I get the materials for this fix? just found out mine is leaking too.
BTR is offline   Reply With Quote
Page generated in 0.22534 seconds with 13 queries
