Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > RealTune Performance
Old 11-13-2006, 10:53 PM   #31 (permalink)
BluFlame's Avatar
Member Number: 8399
Here's my question,.....Does the DCR oil pick-up affect the results at all? Do people who have them see more gains than the people who don't? I ask because it seems as if the DCR pick-up is ramming the oil up to the head due to it's increased flow design and it needs something to slow it down(modifier). My buddy without the modifer has a cold start oil pressure of 90 and above with the DCR pick-up tube.
My pressure is only sitting around 70 on a cold start at idle. I have a custom pick-up with the screen area opened up but other than that it's still stock. Maybe the people seeing gains are the ones who already have that custom pick-up tube and need to slow the flow down?? Don't know,....it's just a thought. Would it benefit me to run a lighter weight rather than the 20-50(Break-In) I'm running right now, if I got this mod??
BluFlame is offline   Reply With Quote
Old 11-15-2006, 02:02 PM   #32 (permalink)
Member Number: 11681
Trader Rating: (96)
Ill be putting this in my car pretty soon. Id like to maybe even install at the track and check times but not sure if i can arrange that or not.
2nd Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
3147 7.49/102 11.51/124 so far 28psi
3147 7.26/100 22psi pump full int
Old 11-15-2006, 07:40 PM   #33 (permalink)
BluFlame's Avatar
Member Number: 8399
Bump for answers
Old 11-15-2006, 09:50 PM   #34 (permalink)
darrell cox's Avatar
Member Number: 35031
Trader Rating: (182)
Does not effect the results at all. Same gains with or without. The DCR pick up tube does not "ram" the oil into the head but simply keeps the oil pump from cavitating and starving itself for oil under demand. The oil pressures remain the same though with and without the pick up tube. If you show a difference in oil pressure it could be a difference in oil brand, weight, oil filter; miles on oil, difference in oil pressure gauges;sending units and wear in the engine. Gains are with or without the pick up tube and are the same.
Thanks
Darrell Cox Racing 276-956-2082
PayPal Addy; darrell@dcrsrt.com
Email; darrell @dcrsrt.com
Website DCRSRT.COM
The Fastest & Quickest SRT4s! Proven DCR Strokers! New DCR 2.8 Stroker! New DCR Pro Mod Heads
In House Dynojet Dyno! Machine Shop! Anything Custom
The Leader in SRT4 Performance!
http://www.srtforums.com/forums/f258...rvices-485754/
1st Stage 3 500+whp all boost!
darrell cox is offline   Reply With Quote
Old 11-30-2006, 10:54 PM   #35 (permalink)
Member Number: 15950
Trader Rating: (42)
Ok i am ready for mine. Paypal sent. Good thread BTW.
Randy
Back-n-Black is offline   Reply With Quote
Old 12-03-2006, 01:07 AM   #36 (permalink)
Trader Rating: (96)
well i got mine but since tranny isent happy with me its about useless....more money
Old 12-03-2006, 01:48 PM   #37 (permalink)
Trader Rating: (42)
Sorry to hear about the tranny Dan. I was wondering when driving it like a raped ape was gonna catch up to it, but i expected some broken axles first. Good luck on getting it taken care of man. I look forward to some new fast times from you.
Randy
Old 12-03-2006, 01:57 PM   #38 (permalink)
OrAnGe-SrT4's Avatar
Member Number: 29828
Trader Rating: (30)
Curious Aaron, what type of oil and oil viscosity do you run in the car. What thickness do I need to actually run the 30psi pressure. I know running say 5w-30 will rate me a higher oil pressure than say 10w-40. right now I'm using Motul 10W-40
OrAnGe-SrT4 is offline   Reply With Quote
Old 12-04-2006, 09:11 AM   #39 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (431)
I did the initial testing with 10/40 and 20/50. Its fairly close between the two. I run 20/50 now
www.Realtuned.com
Each car built/tuned/track prepped in house
{9.98@144 Squishy332000 build}{10.08@148 Erabbit23 build}{10.26@142 Fred@Realtune build}{10.62@138 Karkraft build}{10.88@129 90VNT build}{10.97@136 srt4me18 build}{10.99@135 Mezturbo4 build}
{11.62@128 Realtune Caliber}{11.85@119 Whoosh@Realtune Caliber}
Home of the Worlds Quickest/Fastest CSRT-4, Manual NSRT4, and Stock turbo SRT4
Old 01-05-2008, 09:46 PM   #40 (permalink)
ojcool's Avatar
Member Number: 19382
Trader Rating: (13)
Hmmm, obviously running thicker oil is going to exacerbate this problem. I'm a little tentative about doing anything that is going to reduce the oil pressure below what the engineers designed. But over time if it proves to not cause damage I might get onboard with this. Big difference in doing something to a race car and a daily driver.
ojcool is offline   Reply With Quote
Old 01-06-2008, 02:32 PM   #41 (permalink)
Member Number: 623
Hows 14-15 months with about 1000 orders with zero failures sound
Old 01-06-2008, 03:10 PM   #42 (permalink)
BoostLee's Avatar
Member Number: 26266
Trader Rating: (118)
Sounds like a plan, man.
www.realtuned.com
11 Second Club, AEM EMS, Crane 14's, 44lb/Gated/Ported/Bell-Mouthed/Anti-surged S3R
BoostLee is offline   Reply With Quote
Old 01-08-2008, 01:21 PM   #43 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (65)
It works for me. It also works on your dogs as well
http://www.SRTCanada.com <----- alternate site for canadians.
DiabloSport Trinity Beta Tester
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Page generated in 0.19167 seconds with 13 queries
