Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > RealTune Performance
Old 10-31-2006, 04:14 PM   #16 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Quote: Originally Posted by dasmopar
Yeah man post the info here so other people can see what we are talking about and how it works. Advantages and what not.
DAS,
3 peak HP and 12 more to redline, no increase in peak Trq, but 20 more to redline. Per my dyno comparison. ON a stock turbo and 22 psi.
FYI,
Marion
Powered by Mopar Stage 1/3 Hybrid.
Cincinnati's next SRT's in the 11's
mario03srt is offline   Reply With Quote
Old 10-31-2006, 04:17 PM   #17 (permalink)
dasmopar's Avatar
Member Number: 6413
Trader Rating: (148)
DAS,
FYI,
Marion
Thanks marion. So what power you up to now? Soemone needs to catch Donsrt4
dasmopar is offline   Reply With Quote
Old 10-31-2006, 04:25 PM   #18 (permalink)
ninja5611's Avatar
Member Number: 21261
Trader Rating: (13)
DAS,
FYI,
Marion
nice
ninja5611 is offline   Reply With Quote
Old 10-31-2006, 04:29 PM   #19 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
DAS,
FYI,
Marion
DAS,
That Don dude is uncatchable. I can't get my Sneaky Pete to work right. I got it from FBM and it does not work right j/k.
Supposedly, I have 305 peak HP. My clutch spun on the dyno in 4th so the stocker clutch is going south.
Marion
Old 10-31-2006, 06:22 PM   #20 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (431)
DAS,
FYI,
Marion
We are still working on that. Everytime we go faster, something else takes a poop. I think the DCR head will get us our power back from the leaking valve job we have now, and that should seal the deal. However Im betting that Don fellow beats his own time first.
Im not sure if you heard, but we finally got the the car in the low 12s after months and months of broken stuff
12.07 with 19psi. If I turn the boost up anyhigher it goes 12.40s
www.Realtuned.com
Each car built/tuned/track prepped in house
{9.98@144 Squishy332000 build}{10.08@148 Erabbit23 build}{10.26@142 Fred@Realtune build}{10.62@138 Karkraft build}{10.88@129 90VNT build}{10.97@136 srt4me18 build}{10.99@135 Mezturbo4 build}
{11.62@128 Realtune Caliber}{11.85@119 Whoosh@Realtune Caliber}
Home of the Worlds Quickest/Fastest CSRT-4, Manual NSRT4, and Stock turbo SRT4
Old 10-31-2006, 07:37 PM   #21 (permalink)
dasmopar's Avatar
Member Number: 6413
Ahh have no worries Aaron I keep tabs on what you and Mez are up to. Not to pick a fight but I told you long ago it is harder than it looks to run 11's on the stock turbo and you guys are proof. I know alot of people still think it's just a matter of throwing money at it and going to the track but Dan, Marion, you, and I know better. It's a ton of work and effort to do it. I'm sure mez's car is just a few more passes from being in the 11 sec club now but it has been a long hard road to haul. Same thing goes for the 10 sec mark on any set up. I now have more than enough power to run mid to low 10's but getting the car to stick it to the ground is alot of work. Plus all the little issues that pop up as you keep pushing the envelope.
Peace
Lon
Old 10-31-2006, 07:45 PM   #22 (permalink)
Member Number: 623
Peace
Lon
Oh trust me, I never said it was going to be easy I just know we can do it. But this car has been a train wreck. I really do think its alot easier than what we have been through though.
2 trannies, 3 clutches, broken shifter, broken shift selector, 2 blown pcms, and now leaking valves
Im fairly certain with this setup and a healthy car, it would go 11s pretty much all day.
Alot of it has to do with driver also. His car was breaking so much, he couldnt get much seat time. To run an 11, you need to be whoopin the balls out of the car
Old 10-31-2006, 08:44 PM   #23 (permalink)
flybye4's Avatar
Member Number: 28094
Trader Rating: (103)
this mod sounds really temping and i will be getting one very soon. i just cleared my account on a new FMIC to replace my old one. and also a few other goodies. i just need about $30 in there and ill be hitting you up
oh and yes it is hard to hit 11's on stock turbo. i think you get to a certain point and then after that it takes ALOT. for awhile i was confused on how mez's car and many others were running the times they are. then i go out with just a needswings DP, mapclamp tuned by aaron (almost a year ago), ported TB, WG, MBC, slicks and a few other non power adders. and run a 12.6??? maybe im lucky or just a good driver i mean i was pulling 1.7 60ft my second time down the track and for the rest of the night. and was also my first time on slicks in this car with only 8psi in them
04' Yellow Jacket M6 GTO
99' Dark Bronzemist Metallic 2dr GTP
04' Metallic Silver SRT-4......SOLD
flybye4 is offline   Reply With Quote
Old 10-31-2006, 08:48 PM   #24 (permalink)
dasmopar's Avatar
Member Number: 6413
Yeah getting past 12.3 is the first major jump. Then it gets harder and harder. You know how you go to the track and run say a 12.9 a 12.7 a 12.8 then boom a 12.5 well that doesn't seem to happen once you get past 12.3 well not for me any ways. Now you are at a best of 12.3 so now you just start nibbling off 0.05 here and there. I can tell you once you get to 12.0 it gets even harder. This oil modifier might be the trick for a few cars sitting on the bubble right now who knows?
Old 10-31-2006, 08:54 PM   #25 (permalink)
moltenice's Avatar
Member Number: 6528
Trader Rating: (24)
good thread.......
...Brandon
moltenice is offline   Reply With Quote
Old 10-31-2006, 09:48 PM   #26 (permalink)
flybye4's Avatar
exactly.....thats where i got stuck this year is with the mid 12's. but that is mainly just because i had some serious financial issues. and then being stuck with such a shitty local track. i am also trying to max the stock turbo and hope to lay down some good times next year. just trying to find a good welder and porter right now, for my new setup . i just need a few more things to top her off. but i know they are gonna cost some bigs bucks. oh and one of you norther boys better be ready to tune this POS real soon.
Old 10-31-2006, 10:18 PM   #27 (permalink)
SRTVenom's Avatar
Member Number: 8518
So on a scale of 1-10 10 being the hardest, how bad is the install on these???
SRTVenom is offline   Reply With Quote
Old 11-01-2006, 06:11 AM   #28 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
2-3 it's easy.
Old 11-01-2006, 06:27 AM   #29 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
If I could get the skinnies back from J.Moore I have a couple of opportunities left weather permitting. With more HP to redline with the DCR Oil Mod it outta out do the 12.2. I've not ran the car since May on a track as I've been babying it with these long drives to work now amounting to 94k on the odometer. I need a reassignment bad.
But I've kinda lost interest in the goal as I have the STG3 setup in the garage , all i need is a DP.
I'd be very happy with a solid 11 in a STG3 street Neon.
Marion
Old 11-08-2006, 06:57 PM   #30 (permalink)
04yellowsrt's Avatar
Member Number: 32684
Trader Rating: (26)
Marion throw a clutch in that bad boy and get 'er to the track one last time. I'm headed to milan this saturday for one last time this year
2004 Dodge Neon SRT-4 11.02@125
2004 Dodge Neon SRT-4 10.94@133
Quote: Originally Posted by addictedtosin View Post
04yellowsrt is probably THE BEST driver on the boards.
04yellowsrt is offline   Reply With Quote
Page generated in 0.52633 seconds with 13 queries
