Old 07-14-2008, 07:53 PM   #1 (permalink)
ACeR's Avatar
Member Number: 49468
Default "Whistle" noise from engine bay after downshift
Not sure what it is and hoping I could get some help. It's after I downshift and the car is "engine braking". It's periodic, sometimes at higher rpms, sometimes at lower rpms, but usually around 2500-3000ish.
I do have a Greddy Type-S bov and not sure if it's my string not holding. It sounds as it always has. It seems to be working the same.
Thanks for any input in advance!
Josh
The Mystery Skittle - Sold
ACeR is offline   Reply With Quote
Old 07-15-2008, 07:13 PM   #2 (permalink)
ACeR's Avatar
back to the top
Old 07-16-2008, 08:22 PM   #3 (permalink)
ACeR's Avatar
Any help?
Old 07-17-2008, 07:58 AM   #4 (permalink)
XxWicked_MagixX's Avatar
Member Number: 38697
does it sound kinda like a supercharger? , could be tranmission noise... i know i could hear mine a lot more with solid mounts....
define whistle noise i guess.. it could be anything
XxWicked_MagixX is offline   Reply With Quote
Old 07-17-2008, 09:59 AM   #5 (permalink)
Member Number: 28019
vacuum leak would be my guess...
mahkis is offline   Reply With Quote
Old 07-17-2008, 08:07 PM   #6 (permalink)
ACeR's Avatar
Not a supercharger sound. My guess is vac leak also. Haven't had a chance to test yet. Thanks for the input!
Old 07-18-2008, 07:48 AM   #7 (permalink)
definitely vacuum then...
Old 07-18-2008, 09:02 PM   #8 (permalink)
ACeR's Avatar
Been listening closely lately and there is a bit of noise when boosting, but you can only hear right when you start in first gear when driving next to a wall. Because of my side exit, once you get goin the exhaust note and the air make too much noise to hear it under boost.
I'm goin to boost leak test tonight.
Old 07-20-2008, 05:07 AM   #9 (permalink)
ACeR's Avatar
No apparant cause for the noise. No leaks. Throttle body was makin different noises than usual when the air passes by though.
Old 07-21-2008, 10:31 AM   #10 (permalink)
Srto488's Avatar
Member Number: 57895
Your intake manifold gasket could be leaking...My car did the same thing. WHen i turned it on it would do it for like 2 secs but as the day went on it got worse and worse to the point that it was always doing it...Look by your injectors and see if the gasket is blown cuz you could actually see mine sticking out a little bit...
Srto488 is online now   Reply With Quote
Old 07-21-2008, 11:36 PM   #11 (permalink)
ACeR's Avatar
Performed a boost leak test and opnened the trhottle body while diong it and no leak at the intake gasket.
Just sold the car today though so the problem is no longer mine. Still think it might have been the bov or the throttle body needed replaced/repaired.
Page generated in 0.16759 seconds with 11 queries
