Old 06-29-2008, 07:42 AM   #1 (permalink)
Member Number: 51751
Default what is the Vacume Leak test procedure
How do you find a vacume leak? Ive checked all the vac lines I can see. Ive pulled the injectors out and map and reinstalled them. Can you check for a vac leak like you do a boost leak?
I'm only reading 15 at an idle and 19-20 on decel even from a high rpm down hill. Ive got stage 2 and it hardly pops on the decel. If I pump the brake a little I can get it up to about 10 and the things idling pretty high.
dohc122acr is offline   Reply With Quote
Old 06-29-2008, 07:51 AM   #2 (permalink)
mebcop's Avatar
Member Number: 42028
Trader Rating: (10)
I've used carb/choke cleaner and spray it in the areas of possible leaks while the car is running. If the idle races for a second, you've found your leak. Spray around the intake manifold gasket, the throttle body gasket, and I've done around the vacuum hoses too. Good luck man.
AGP return line, AEM SRI, AEM UEGO Wideband, VRS 3 inch Exhaust, Maxxfab 3" DP w/o cat, DW 750's, MPx FMIC , 50 Trim AGP, HKS SSQ BOV, Turbonetics evolution wastgate, OBX IC pipes, Labonte Motorsports W/M kit, SBC Stage 5 clutch, Perrin MBC, Maddog 80% STS, bottleneck fix, walbro 255, Bwoody MM, AEM 3.5bar Map Sensor, Rage-Tek Map Sensor Adapter.EMS INSTALLED: 433 WTQ ON A MUSTANG DYNO UNCORRECTED WTB:TRACTION HAHAHA
mebcop is offline   Reply With Quote
Page generated in 0.12798 seconds with 11 queries
