what are syptoms of bad map sensor? - Dodge SRT Forum
post #1 of 21 (permalink) Old 03-08-2011, 10:27 AM Thread Starter
Quoted: 0 Post(s)
what are some syptoms of a bad map sensor.. everyones telling me to replace it but no one can tell me what the causes of a bad map sensor will do
2003 Solar Yellow SRT-4
grocery getter.
Bubbaryan17 is offline
post #2 of 21 (permalink) Old 03-08-2011, 10:58 AM
StockTurboJamson's Avatar
Quoted: 0 Post(s)
surging, bucking, rough idle, bad gas mileage, rich condition, detonation, sputtering. all that fun stuff could be associated with a bad map sensor. do you have access to a good scan tool to see what the map sensors saying?
276hp, 373 lb.ft. stock turbo (mustang dyno)
StockTurboJamson is offline
post #3 of 21 (permalink) Old 03-08-2011, 11:24 AM Thread Starter
Quoted: 0 Post(s)
I have a diablo idk if that can read it or not
grocery getter.
post #4 of 21 (permalink) Old 03-08-2011, 07:41 PM
Quoted: 0 Post(s)
whats the car doing?
post #5 of 21 (permalink) Old 03-09-2011, 09:05 AM Thread Starter
Quoted: 0 Post(s)
my air fuel gauge is all over the map.. did a compression test and all 4 r great.. checked turbo, its great, when your driving it its fine. but however if u come to a stop or let it idle for about 15, seconds or more oil smoke starts comming out the exhaust.
grocery getter.
post #6 of 21 (permalink) Old 03-09-2011, 09:06 AM Thread Starter
Quoted: 0 Post(s)
oh and rough idle messed with the tps sensor and nothing changed
grocery getter.
post #7 of 21 (permalink) Old 03-09-2011, 09:18 AM
KBzPTGT's Avatar
Quoted: 5 Post(s)
how is oil smoke associated with a bad MAP sensor?
Swap your sensor with a known good one
KBzPTGT is offline
post #8 of 21 (permalink) Old 03-09-2011, 09:39 AM Thread Starter
Quoted: 0 Post(s)
Smile
i have the three bar map with the diablo but havent put it on yet
grocery getter.
post #9 of 21 (permalink) Old 03-09-2011, 07:06 PM
srt4srsexy's Avatar
Quoted: 0 Post(s)
what kind of a/f you got? bad map can cause bad a/f ratios cause the car to be lean/rich retard timing or advance.map sends signal to pcm to add fuel and timing or vice versa depending on engine load. do you have a three bar in there now and are you big turbo if you are yes you should have three bar in.
srt4srsexy is offline
post #10 of 21 (permalink) Old 03-10-2011, 09:38 AM
XxWicked_MagixX's Avatar
Quoted: 0 Post(s)
sounds like your building crankcase pressure, if your sure the turbo is good and oil smoke is coming out, check your pcv valve and line. if those are good, check your drain line on the turbo
XxWicked_MagixX is offline
post #11 of 21 (permalink) Old 03-10-2011, 09:41 AM
Quoted: 0 Post(s)
Plug a scanner to the car check the pids and look at the map sensor and tps they should be pretty close together. If the map is reading like really high or 5volts then your shorted. You have to check all your wiring. Your sensor may not be bad it's probably the wiring or connection.
Kayyyle is offline
post #12 of 21 (permalink) Old 06-23-2011, 01:55 PM
orangeneon21's Avatar
Quoted: 0 Post(s)
My engine code throws 2074 and my prob. Is similar to all this.
Last edited by orangeneon21; 06-23-2011 at 01:57 PM. Reason: But no smoke but I am having a whit sling sound
orangeneon21 is offline
post #13 of 21 (permalink) Old 07-14-2011, 05:33 PM
DrmCtchr's Avatar
Quoted: 0 Post(s)
multiple problems .. the smoke is valve stem seals, likely. the AFRs are probably a bad map or more likely a fouled O2 sensor(s) from the oil leaking into the combustion chamber.
DrmCtchr is offline
post #14 of 21 (permalink) Old 07-14-2011, 06:19 PM
_Nick_'s Avatar
Quoted: 1 Post(s)
A bad 02 housing gasket can throw off AFR's as well, but they would be lean.
20G Stage 3 on E85: New data:384 hp 411 tq
"Maybe I should just stick to bolt-ons." -Hitler
I don't really want to wrench anymore. I'd rather detail.
_Nick_ is offline
post #15 of 21 (permalink) Old 10-31-2011, 05:46 PM
ryeinbee's Avatar
Quoted: 0 Post(s)
Hey guys, need some help.
My cars bogging right out at around 2300 rpms and seems like its gonna die until you let it go back down past 2300... the CEL code is coming up as 'camshaft sensor'. i changed that and no luck. changed plugs, wires and ignition coil and still no luck. ordering a new cat converter.. do you think it could be the MAP sensor??
please get back to me asap
Ryan
ryeinbee is offline
User Tag List
Linear Mode Linear Mode
