how do i get rid off P0128 Coolant Thermostat im a newbie so any help will be great... i put coolant but i doesnt go away
one either the thermostat is going out or the sensor to the thermostat is going out. get a 180 thermostat put it in your car reset the ecu then see if that fixes it. if not its the sensor on the side of your coolant housing where you put coolant in it.
SRT-4 is built in the US with 84% US content.
A New 06-07 Mustang is built in the US with 64% US content and does not legally qualify to use the term "Made in the USA". How's that for an import? Stock turbo/ 3'cai, 3"O2 housing, 3"DP, AGP WGA, mild port head w/3angle valve job w/crane springs retainers,2.0 cams w/fidanza gears, ED hard pipes, hks bov,fullybuilt ported 55mm tb. thats just the begining
still confused on how to do the sequence with the key i have a turbo timer does that make any difference?
the following sequence with the key: ON-ACC-ON-ACC-ON wats ACC
Got in my car this afternoon (first start of the day) turned the key but the engine did'nt turn over and check engine light chimed .. tried again and the gauge cluster needles did that scan thing..
.. NO CODE ...BUT the display that would show what code I threw says "FUSE"
??? well i checked the fuse box between driver door and dash, everything looks fine
???ok
So I check the fuse box under the hood and those fuses look fine but i cant tell if the relays are bad or the clear top cubes are bad
???ok
any input will help..
-thanks Mike
battery is no good get it replaced
stage 2 with toys and stuff i don't want you to know
