Old 04-08-2007, 10:04 PM   #46 (permalink)
JohnnySrt4's Avatar
Member Number: 44657
Does anyone know what code P0129 is?? I just installed my Apexi AFC Neo and after about the 3rd crank it pops up. its not up in the code list if anyone can help me out i would appreciate it. thanks.
3 inch down pipe, Cold Air Intake with splash guard, AGP Waste Gate, Apexi Neo Fuel Controller, oil pressure gauge, Wide Band, Air Fuel gauge, Tip Mod, Falcon Azenus Tires, Cross Drilled Slotted Roters,Co2 Inner Cooler Sprayers, SQV BOV, ATP Hard Pipe, re-routed Vaccum lines, Jet Chip, Oil Catch Can, Homemade Block off plate out of Half Inch Steel...
JohnnySrt4 is offline   Reply With Quote
Old 04-09-2007, 03:53 PM   #47 (permalink)
SkienHigh's Avatar
Member Number: 38797
p0129- barometric pressure out of range low
SkienHigh is offline   Reply With Quote
Old 04-09-2007, 04:29 PM   #48 (permalink)
m00m00w4t3r's Avatar
Member Number: 41979
how do i fix these 2 CEL:
P1105 Secondary Vacuum Sensor Circuit
p0033 - surge valve solenoid circuit
m00m00w4t3r is offline   Reply With Quote
Old 04-10-2007, 12:25 AM   #49 (permalink)
JohnnySrt4's Avatar
How do i fix this?? [p0129- barometric pressure out of range low]
Old 04-10-2007, 01:27 PM   #50 (permalink)
SkienHigh's Avatar
that one sounds like you just tried to take out your solenoids (color hoses) and didnt hook them up right. what mods have u done recently?
Old 04-10-2007, 01:28 PM   #51 (permalink)
SkienHigh's Avatar
reset your pcm and see if it comes back. if it does, trace over your wiring in your safc neo to be sure you didnt wire something up out of place. then check for nasty boost leaks. does the car run funny?
Old 04-10-2007, 04:52 PM   #52 (permalink)
the only recent one i did was FMIC which was 3 weeks ago and 2 weeks ago i plugged the solenoids back in according to the color.
Old 04-10-2007, 09:47 PM   #53 (permalink)
SkienHigh's Avatar
well then it sounds like you hooked up the solenoids wrong when u put them back on there. double check and reset pcm. see if that works.
Old 04-11-2007, 02:54 AM   #54 (permalink)
for the solenoids you know how theres 2 plug holes? there is no specific way to connect correct?
Old 04-11-2007, 10:20 PM   #55 (permalink)
SkienHigh's Avatar
that i dont know. my friend here did all my solenoid removal so i really have no idea.
Old 04-15-2007, 02:16 AM   #56 (permalink)
TheDodgeWraith's Avatar
Member Number: 45980
Whats EOT for p1188
Yay!!!Yay!!!
TheDodgeWraith is offline   Reply With Quote
Old 04-24-2007, 04:39 PM   #57 (permalink)
Member Number: 52097
how do i get rid off P0128 Coolant Thermostat im a newbie so any help will be great... i put coolant but i doesnt go away
johnny2j2 is offline   Reply With Quote
Old 06-05-2007, 05:41 PM   #58 (permalink)
Member Number: 25137
i have a code and i dont know what it is p 0335
srtboost0514 is offline   Reply With Quote
Old 07-21-2007, 11:33 AM   #59 (permalink)
s ar tee 4's Avatar
Member Number: 54654
nice nice nice
s ar tee 4 is offline   Reply With Quote
Old 07-26-2007, 12:44 PM   #60 (permalink)
projekt's Avatar
Member Number: 54655
this helped me out so much....
i was throwing a p0300 and a p0123
engine misfire,and throttle positioning sensor...
replaced throttle positioning sensor... and runs like a dream
projekt is offline   Reply With Quote
Page generated in 0.28955 seconds with 11 queries
