two options, go to an autozone and have them scan the car for free, or go to your dealership and pay what ever the rate is there and have them scan the car
but there isn't any reason why you shouldn't be able to do the three cycles and have the code pop up.
you do the key to on, (not starting the car) three times. so you do on, off----on, off----on and on the third on the mileage area should blink with a p code. the only time this can get tricky is if you have a turbo timer. if you do make sure it is turned off
Nah............I've had 2 different turbo timers in the car in the past but I don't have any in at the moment..................I've tried to check codes like this every now and then in the past but it has never shown me anything. Maybe because my car was one of the first one's out???
Check engine light on my company's pt cruiser, but it doesn't get any cels. Is there anything else I can do besides bringing it into autozone for a scan?
sorry guys..........tried the search, found a code list but the code i need wasn't on it...............dont know where else to look !!!gotta fix this damn car!!
anyways it's a 02 intrepid.........code is p1776
trans is acting up.drives normal until you slow enough for it to kick down to
2nd gear , then stays there ! shut car off and restart, tranny shifts fine again.........until you slow down again !!!
ANY help would be greatly appreciated !!!!!
What can be causing this?
After happens, the check engine comes up and codes p0522 comes up and P0108, I bought the sensor of oil, but what can be causing the p0108 code in the map???
PLeasE HelP the Car Goes Nuts and Sometimes won't start!
Stage 1, LoBoost 18psi/HiBoost 24psi on PT 61Turbo/ EBC Greedy Type S/Needswings V6 Downpipe on Stock Exhaust/Stainless steel intercooler pipes/GreedyTypeS BOV/Tial 38mm Adjusted to AGP p/c manifold/Walbro 255 fuel pump/RC750cc with AGP Modded Return Kit/ Apexi SAFCII with tach/AGPRACE FMIC/63mmTbody /180 thermostat/ Mopar STS/Booshings/ ClutchMasters Stg3 6pk/Fidanza Aluminum Flywheel/Koyo Radiator/Samco Hoses/AGP Oil Catch Can
i see u having problems to mr fsh....so how can i fix p2074 i have cheked evry vacum line and manifold for leaks but nothing and the other is how can i fix p1188???
ok guys is there someone know what the 0627 code. its between generator circuit high votage 0626. and fuel pump relay 0628.
SRT-4 is built in the US with 84% US content.
A New 06-07 Mustang is built in the US with 64% US content and does not legally qualify to use the term "Made in the USA". How's that for an import? Stock turbo/ 3'cai, 3"O2 housing, 3"DP, AGP WGA, mild port head w/3angle valve job w/crane springs retainers,2.0 cams w/fidanza gears, ED hard pipes, hks bov,fullybuilt ported 55mm tb. thats just the begining
